Old 04-25-2010, 02:50 PM   #1
catmull32
how to identify high hump vs low hump??
I was just wondering if anyone could explain to me what the difference is and how to identify them
catmull32 is offline   Reply With Quote
Old 04-25-2010, 02:58 PM   #2
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: how to identify high hump vs low hump??
Here ya go.
http://67-72chevytrucks.com/vboard/s...=low+hump+high
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 04-25-2010, 03:01 PM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
High hump is bolted in.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 04-25-2010, 09:39 PM   #4
High hump comes up as high as the seat bottom in front of the seat.
Old 04-25-2010, 11:53 PM   #5
1969C10shortbed
I think mine came factory low hump, but it has a shifter on the floor. The hump looks hastily cut. If I were to replace the entire floor (yes, it needs it) should I go with a high hump? I plan on swapping a T56 or similar into it behind a big block later on.
1969C10shortbed is offline   Reply With Quote
Old 04-26-2010, 08:44 AM   #6
Only low hump floors are made.You can cut and install a high hump,though.
Old 04-26-2010, 03:57 PM   #7
catmull32
Two wheel drive floor pan vs four wheel drive floor pan? Are they the same?
Old 04-26-2010, 04:06 PM   #8
68350
68350's Avatar
only if the 2 wheel drive had a high hump. all 4wd had high hump.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 04-26-2010, 07:07 PM   #9
The pans are the same and interchangeable.Only the hump itself is different.As 68350 said,all 4wds had high-hump and only big block or 4spd 2wds did.But,the impression is there for the bolting surface of the high hump.GM offered replacement cabs for a while,but only non-air low-hump.Instructions were included for adapting for both a/c and high-hump.
Old 04-30-2010, 12:30 AM   #10
1969C10shortbed
http://www.classicparts.com/1969-72-...tinfo/45-920B/
So this one is unfortunately a low-hump? And I would need a tall hump?
Old 04-30-2010, 10:33 AM   #11
Yes,you can cut the hump out,lay high hump over,drill through mounting hole locations,tack nuts underneath,and you`re done.This is what I`ll be doing on my rust free California cab for my`67 project.I`m using an M22 4spd (which works under a low hump) and I want a high hump for easier access to the shifter assembly.It`s a pain to mess with that stuff all up against the floor and over the transmission.
Old 05-02-2010, 05:54 PM   #12
1969C10shortbed
Alright, thanks for the info!
Chris
