Old 05-11-2010, 07:36 AM   #1
skeeterbug
skeeterbug's Avatar
stock sway bar question
i have a 71 1/2 ton lwb just wondering if an 73 3/4 ton heavy duty front sway bar will work on my truck with no mods?
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 05-11-2010, 10:26 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: stock sway bar question
Yes it will fit. You will need to get the correct bushings if you replace them, everything else should bolt up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-11-2010, 12:18 PM   #3
skeeterbug
skeeterbug's Avatar
thanks n2trux, my truck did not have a factory swaybar or was removed by the po. which bushings are you speaking of exactly as the correct ones?
2013 best 7.39
2014 best-7.38
Old 05-11-2010, 05:19 PM   #4
michael bustamante
michael bustamante's Avatar
I have a 78 3/4 ton sway bar on mine with my original brackets and new bushings from o reillies, worked, no problem
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2010, 08:49 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
skeeterbug I misread your post. I thought you were upgrading to a C-20 bar. The bushing I referred to are the ones that are clamped at the frame. In your case you will have the correct size bushing.
Articles-
"Refining Sierra"
