Old 06-06-2010, 12:21 AM   #15
westofb
I really hate wet sanding!
westofb's Avatar
Re: Western Chassis Flip Bracket/U-bolt options
Originally Posted by bigblock73 View Post
You wouldn't put a dirty worn out floor mats in your cab after you just installed new carpet would you? ;D
No probably not...but if they were in good shape I might clean them and re use them again. I built my truck to drive, not for being towed around in a trailer...and if you want to climb under it and diss my surface rusted re used factory parts, that is up to you. Why not re use parts if they are servicable? I have to work hard for what little I got, why spend money on stuff that does not need replaced! I rarely climb under my truck and wax the u bolts, I could care less what they look like, just that they do the job they were intended to do.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
