Old 06-06-2010, 10:34 AM   #20
bigblock73
yeller
bigblock73's Avatar
Re: Western Chassis Flip Bracket/U-bolt options
Originally Posted by westofb View Post
No probably not...but if they were in good shape I might clean them and re use them again. I built my truck to drive, not for being towed around in a trailer...and if you want to climb under it and diss my surface rusted re used factory parts, that is up to you. Why not re use parts if they are servicable? I have to work hard for what little I got, why spend money on stuff that does not need replaced! I rarely climb under my truck and wax the u bolts, I could care less what they look like, just that they do the job they were intended to do.
So those custom wheels, custom paint, and c20 to c10 conversion were all "needed"?
Not sure why you had to quote me, as if I were directing my post to you (which obviously I wasn't), but I will return the favor and quote you and try to understand your logic as you were trying to understand mine.
bigblock73 is offline   Reply With Quote
