Old 06-13-2010, 08:32 PM   #1
CenValyCali
Changing air cleaner and valve Covers on Smog truck
So My truck just passed smog for the first time since I've had it . I'm thinking I won't have to smog it for another 2 years and I just can't stand the air cleaner or the valve covers and was hoping to swap them out. How do I do this with out screwing anything up? I've got a pipe that goes from my valve cover to my air cleaner that would need to be remover and a few other hoses that go to the air cleaner. Let me know please and thank you.
Adam
CenValyCali is offline   Reply With Quote
Old 06-13-2010, 11:59 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Changing air cleaner and valve Covers on Smog truck
If it looks anything close to this snake pit, Good Luck! i've been down that road already and it ain't worth it
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 06-14-2010, 01:33 AM   #3
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Valve covers are no problem, since most applications I've seen allow for the installation of the PCV valve. The air cleaner is another matter. I use an aftermarket air cleaner, except when I smog my truck - then the stock set-up is reinstalled for the test. Makes life a whole lot easier.
78 Big10 454 is offline   Reply With Quote
Old 06-14-2010, 01:49 AM   #4
CenValyCali
That's my plan, Put everything back on when it comes time to smog. Do you have a picture of under your hood? I'd like to see it. Thanks
Old 06-14-2010, 01:57 AM   #5
85silverbeast
85silverbeast's Avatar
I have an edelbrock air cleaner and passed smog without a problem. Mine came with the adapter to connect the hose that comes out of the driver side valve cover.
85silverbeast is offline   Reply With Quote
Old 06-14-2010, 02:05 AM   #6
CenValyCali
Do you have a link to the air cleaner? Thanks
Adam
Old 06-14-2010, 07:45 AM   #7
85silverbeast
I bought from autozone it was about 35 dollars Edelbrock 14' air cleaner part number 1221
Old 06-14-2010, 11:53 AM   #8
benoit454
Chris
benoit454's Avatar
remove air cleaner and snorkel tube, block vac. lines with a plug or screw and route them out of the way or sight, then install any reg. open element of your choice, and throw on some other valve covers and be done.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-14-2010, 01:56 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
Post some before and after pics when your done
