Old 06-17-2010, 08:43 PM   #3
chevymotocross
chevymotocross's Avatar
Re: Western Chassis Flip Kit retaining plate question
Hmm, I actually started out tightening it with the center hole and it just seemed so uneven, off to one side to much. I installed them, before I read your reply of course, in the offset hole which seemed to fit better.
I don't think it affects much, the u-shape bracket is what aligns the axle. With the retaining plate as it is now, all u-bolts are spaced evenly, as well as the plate. I did test drive it for quite a bit, seemed fine. I will post more details and pics about how the install went. I'll have to give those plates another look if they are indeed suppose to be in the center hole.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
