Old 06-23-2010, 05:27 PM   #1
DBLSPRT68
DBLSPRT68's Avatar
1/2T long wb truck weight?
Can someone tell me the weight of an 81-87 1/2T 2wd lwb truck? I need to know and don't have one "at the moment"! Will post pics later
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 06-23-2010, 07:10 PM   #2
Slofarmtruck
Re: 1/2T long wb truck weight?
My 84 C10 2wd LWB weighed in at 4500 lbs without me in it. Hope this helps.
Slofarmtruck is offline   Reply With Quote
Old 06-23-2010, 08:09 PM   #3
hotrod_991
hotrod_991's Avatar
wrong year but my 77 wieghs in at 62xx she a heavy ole girl.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 06-23-2010, 08:55 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
You wanting the GVWR? 81 LWB is 6100.
RandyP is offline   Reply With Quote
Old 06-23-2010, 09:08 PM   #5
Copytech
Really? My '84 C20 weighs 4200lbs full of fuel and me in it (190lbs).
Copytech is offline   Reply With Quote
Old 06-23-2010, 09:10 PM   #6
RandyP
RandyP's Avatar
I gotta ask, how do you guys know what your truck actually weighs? I can barely find scales to weigh myself.
Old 06-23-2010, 09:17 PM   #7
DBLSPRT68
DBLSPRT68's Avatar
Thanks guys, I'm wanting to know the weight of the truck itself. 4000-4500 sounds about right. That's what I was looking for. I'll be pulling "it" on a tow dolley if "it" will fit. I've got to get measurements, but I'll go to a JY to get that. Just wandering if "it" outweighed the tow vehicle. It doesn't! Did ya'll get that? Will post a pic in about two weeks when she's home. David
Old 06-24-2010, 02:39 AM   #8
hotrod_991
hotrod_991's Avatar
haha hey man i just towed my 6200lb longbed 2wd from montana to souther TX on a uhaul car dolly loaded with a bed and other crap behind an 05 ford ranger 4x4 also loaded to the hilt. 1500 milesno issues sept horrible gas mileage. Also it will fit on the dolly the edge of the tire will just barely be to wide. It will strap down tho and be safe but FYI tho make sure you unlock the steering wheel cause the truck weighs to much for the dolly's wheel pad to pivot like it is supose to. good luck
Old 06-24-2010, 04:04 AM   #9
DBLSPRT68
DBLSPRT68's Avatar
Thanks for that info. Does your truck have 7 inch wheels or 8's. I actually thought about finding some stock steel 7's (or van rallies) and old tires at the junkyard to put on the dolley side(front only). The truck has the wide 8's on it, so I'm thinkin I'll have to do this anyway. BTW, the truck I'm going to get is one of those extended cab's
Old 06-24-2010, 07:12 AM   #10
Copytech
Buy some bulk dirt or gravel, you have to weigh in and out.
Old 06-24-2010, 11:22 AM   #11
Slofarmtruck
I just went off what the scale said at the local dairy place!
Old 06-24-2010, 11:46 AM   #12
hotrod_991
hotrod_991's Avatar
I have 7's in the front i would deff find just a crappy set or skinnies for the front so you dont have any issues
Old 06-24-2010, 01:12 PM   #13
qu1cks1lver56
qu1cks1lver56's Avatar
last time i was at the dump, with me in the truck my 86 was 4380 with about 6 gallons of fuel.
qu1cks1lver56 is offline   Reply With Quote
Old 06-24-2010, 01:20 PM   #14
larrystone
larrystone's Avatar
My 1986 weights only 3900 pounds with the military front end guard which is 43 pounds.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 07-13-2010, 11:20 PM   #15
DBLSPRT68
DBLSPRT68's Avatar
hotrod, you ain't kidding! Even with the junkyard skinnys on it; it just barely fit on the u-haul tow dolly! I didn't get a pic of it, thinking I might get a ticket or a lawsuit filed against me..... It just barely fit! No other issues with the 3 hour trip home. Here it is at his new home. Thanks for the help guys! David
Old 07-14-2010, 12:27 AM   #16
westofb
I really hate wet sanding!
westofb's Avatar
Don't tell U Haul what you are towing or they won't rent the dolly. I have used their car trailers to haul these trucks, the long bed will fit with a few inches to spare and they tow very nice, I think it costs about $20 more than the dolly on local rentals, oneway rentals depends on where you get it and where you are taking it. If you go with the dolly, tell them its a s10 truck you are towing.
Never mind you got it home...should have read the whole thread before running my mouth!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 07-14-2010, 01:23 AM   #17
DBLSPRT68
DBLSPRT68's Avatar
"tell them its a s10 truck you are towing" That's what I put down. 1985 s10 regular cab. I also got the $5000. insurance just in case..... I've used that before
Old 07-14-2010, 02:20 PM   #18
SS Delux
SS Delux's Avatar
Great looking truck ! I asume that is a custom job because to my knowledge they never made an extended cab silverado.
SS Delux is offline   Reply With Quote
Old 07-14-2010, 02:59 PM   #19
p_rubottom
p_rubottom's Avatar
Read up
http://67-72chevytrucks.com/vboard/s...d.php?t=365878
p_rubottom is offline   Reply With Quote
Old 07-14-2010, 03:31 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
cool truck,get weighed in and out when droppin scrap metal off,other yards should have scales too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-14-2010, 05:27 PM   #21
78 Chevyrado
My 87 lwb silverado weighed around 4400lbs without me in it.
78 Chevyrado is offline   Reply With Quote
