07-17-2009, 09:37 PM | #26 |
Re: Check it out
When you smoothed the firewall how did you deal with the horizontal seam that runs through it? I want my firewall to look just like yours. I'm pulling my engine tomorrow to start smoothing and start my Porterbuilt C4 dropmember install.
Ryan 84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
07-19-2009, 05:30 PM | #27 | |
Re: Check it out
(these tabs will go on the bridge bar with shock bolts like the ones in the bottom picture) (these are from *****************) ... but first I need to install the panhard bar. The whole pinion angle thing. I'll post some pictures of it as soon as I get that done
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:30 AM. Reason: updated pictures |
07-19-2009, 05:48 PM | #28 | |
Re: Check it out
Well first I used a wire wheel to remove all the factory seam sealer (black sh*t), then I found some rust so I had to cut that out and patch in some pieces and grind the welds down. I also had to use a hammer and dolly to get the seam flat in some areas and tacked it down with a few welds and grind some more. Then fill the seam with all-metal body filler and sand smooth. Good Luck its a pain in the ass, but its worth it in the end. ( that sounds funny)
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow |
07-20-2009, 03:46 PM | #29 | |
its just $$$$$
Re: Check it out
07-25-2009, 01:45 AM | #30 | |
Re: Check it out
04-14-2010, 12:18 AM | #31 |
Re: Check it out
I've been busy redoing the rear supension and this is what i came up with. It travels fine without any bineding and the pinion angle doesn't change a bit.
04-14-2010, 08:18 AM | #32 |
Low & Fast!
Re: Check it out
Man I like that, I want to use my stock hanger like that too. How long is that outer link to the hanger?
04-15-2010, 03:39 AM | #33 |
Re: Check it out
Thanks man, the lower bars are 24 1/4" from bar end to the center of the bolt hole for the hanger.
04-15-2010, 05:51 PM | #34 |
Re: Check it out
here is a cool pic...
04-16-2010, 12:37 PM | #35 |
Low & Fast!
Re: Check it out
I just saved that pic! And nice work!
04-17-2010, 12:37 PM | #36 |
Re: Check it out
Thanks again I appreciate it.
Here is an update on the shocks. Now its time to take it all apart to weld it up permanent and paint it all (the frame and suspension).
04-30-2010, 01:33 AM | #37 |
Re: Check it out
Well I finally welded up all the tabs on the axle tubes and made some braces for the rear of them to strengthen them. I even got to paint some parts.
06-22-2010, 02:30 AM | #38 |
Re: Check it out
Well guys I was able to get some more things painted and put together.
I even got the motor in to mock up my headers. They fit very well. I just need to do something about the air cleaner.
06-22-2010, 01:39 PM | #39 |
Re: Check it out
rear set up looks great, nice work!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
06-23-2010, 10:51 AM | #40 |
Re: Check it out
Nice progress!
07-04-2010, 08:57 AM | #41 |
Low & Fast!
Re: Check it out
Looks very good!
07-04-2010, 08:59 AM | #42 |
Re: Check it out
Looks good! What headers did you use?
07-05-2010, 06:40 PM | #43 | |
Low & Fast!
Re: Check it out
Thank you sir.. Trav
07-07-2010, 03:30 AM | #44 |
Re: Check it out
Let me go and measure for you... Yes 2.5". I used the leafspring for refrence. I bought all my steel at the local steel yard. The only things I got from them (S D) were the mounts for the bags and the panhard bar. I made all the other parts from scratch.
Your are welcome and Thank you, it means a lot to me that like my work.
07-07-2010, 08:28 PM | #45 | |
Low & Fast!
Re: Check it out
07-07-2010, 09:40 PM | #46 |
Low & Fast!
Re: Check it out
Can you add some of the pics back to this thread, I would like to move this to the build part of the forums so more people can see it.
Thanks, Trav
07-08-2010, 01:35 AM | #47 |
Re: Check it out
Hedman Headers got them from Summit Part # HED-69648.
