Originally Posted by matt92man
This is what we needed! I am in the starting phase of putting an LS 5.3/4L60E into a 68 Shortbed that I bought w/o engine or trans in pieces. I'm sure this will help me! Still working on the frame and suspension right now, but am getting close to where I need to be for setting in the engine and trans. I went with the ECE kit for the mounts. Has anyone else used this kit? Anything I need to know about it? I will probably wait to start the wiring until after I get the cab finished and painted, then set it back on. Anyone have recomendations for a fuel tank/pump setup for a shortbed, leafspring truck?
I'm using the ECE engine mounts, and a CPP tubular trans crossmember.
No issues with the mounts, just need to drill 4 holes in the stock front crossmember.
It didn't come with bolts that go into the block, but it's otherwise complete.
