#26 |
![]() Join Date: Jun 2007
Re: They listened lets use it!
Anthony.
I just finished a 4X4 one, Critter is working on one and I know there is at least another one with an NV4500. I am in Brockton just over an hour away. Most of my build is in a few threads if you search my name for posts (some is in my signature also).
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#27 |
Good to hear! I would love to come check it out sometime. I test fitted the motor last week and realized that the motor mount pads need to be moved back about 1 3/4" and the front cross member needs to be notched. I picked up some material so I can get started on the welding, but went on vacation last week so work on it has stopped. I also have most of the harness for the 5.3 torn apart, hoping to get that all rewired by this weekend.
I am hoping to get the truck on the road by the end of august. Thanks for all the great info! |
#28 |
![]() Join Date: Sep 2006
This is great I am looking for a LS and tranny now maybe this will help with the hiccups that come with these kinda of upgrades. Everything I do takes twice as much and as long because I screw it up and have to do it over.
#29 |
This is what we needed! I am in the starting phase of putting an LS 5.3/4L60E into a 68 Shortbed that I bought w/o engine or trans in pieces. I'm sure this will help me! Still working on the frame and suspension right now, but am getting close to where I need to be for setting in the engine and trans. I went with the ECE kit for the mounts. Has anyone else used this kit? Anything I need to know about it? I will probably wait to start the wiring until after I get the cab finished and painted, then set it back on. Anyone have recomendations for a fuel tank/pump setup for a shortbed, leafspring truck?
#30 | |
No issues with the mounts, just need to drill 4 holes in the stock front crossmember. It didn't come with bolts that go into the block, but it's otherwise complete. |
#31 | |
Thanks for the feedback. |
#32 | |
Next project: 1970 K10
![]() * Use the stock in-cab tank with an external pump. You will need to install a return line back into the tank. * Use an 87-91 Blazer or Surburban tank that mounts behind the rear axle between the frame. These were TBI trucks and already have the fuel pump in-tank, so you can use an inexpensive OEM pump. * Use a custom made aluminum tank with an in-tank pump.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#33 | |
My electric fans will clear just fine with them in the straight-up position. |
#34 | |
Good idea, I will have to look into that alittle further. |
#35 | |
Are you going to run the OE style electric fans and set them up computer controlled? |
#36 | ||
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-22-2010 at 10:58 AM. |
#37 | |
Thanks for the quick response too. Now to find a tank, Hmmm? |
#38 |
Believe it or not, many on here have had good luck (and good prices) buying new at Advance Auto, O'Rileys, and Auto Zone. I got my pair of 87 tanks from rockauto.com delivered for a few $$ less than I could go to town and buy from one of the above three.
Take advantage of the new forum to make a new post with future questions. That way they wont get buried here and others can see them too.
#39 | |
#40 | |
#41 | |
One fan will go on with "low", and both will come on with "high" from the computer (at least, that's what I hope to do) Now, if you want true low/high operation, you'll need a third relay. I'm still kind of wondering if I want to go through that or not. They also offer an LS swap radiator for 67-72: http://cgi.ebay.com/ebaymotors/67-72...Q5fAccessories Oh, and I forgot to mention... I think he gave me a discount because I went through "ask seller a question" on ebay, and asked for a price quote. Last edited by Jim_PA; 07-22-2010 at 12:20 PM. |
#42 |
#43 |
That's OK. Since this forum opened up, I'm still editing my posts a lot! I haven't quite got the "yo, these engines can be swapped into more vehicles than a square body!" in my head yet.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-22-2010 at 12:52 PM. |
#44 |
![]() Join Date: Feb 2009
Can't wait to get some info from you guys.... I have a 71 c-10, a 2006 5.3L & 4L60E, motor mounts, trans crossmember, and a lot of enthusiasm about the build. Hope I can leverage some lessons learned from you guys!!!
Working on modifying my harness as we speak. Also looking for ideas on air filters... using stock airbox or going aftermarket. Look forward to talking with a lot of you in the near future... and can't wait to see some pictures and follow build threads. Thanks guys |
#45 |
I will start a build thread as soon as I can get back on the truck. I am still trying to come up with ideas about how to modify the motor mounts and cross member....
#46 |
Good to see this dedicated forum. I'll share my experience with installing a 5.3l into a 41 GMC, mounted on an S-10 frame.
#47 |
![]() Join Date: Aug 2010
I'm at the point of installing a 5.3/4L60E in my 57 GMC. Currently the combo is setting on top of the frame waiting for me to slip it into place and fab mounts.
I'll start a thread on the 47-59 forum on the entire project in the future and post the engine install here. |
#48 |
I've got the EZ chassis swap on my 1951/s10. It came with s/10 to 350 SBC motor mounts. I put LS to 350 SBC plates on the engine. There is a pretty good gap that I'm going to have to shim between the two. I'm not too wild about it. Has anyone ever shimmed up a gap like that on motor mounts?
[IMG] [/IMG]It did feel good just to see what it looked like mounted up though.
1951 Chevy 3100 1957 Chevy 3200 1971 2WD Blazer |
| Bookmarks |
