GM ONLY BABY!!!
Which oil pan for 72 GMC 2wd?
I have a 72 GMC truck and am in the midst of rounding up parts for to install a 6.0 LQ4 that came from a 01 Chevy truck. What oil pan will fit mine? I have seen that some guys have to change to the Caddy CST V pan.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
Moderator
![]() Join Date: Jul 2006
Re: Which oil pan for 72 GMC 2wd?
I'm using an f-body pan just for extra ground clearance.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
MAST motorpsorts has one coming out in a few weeks that will fit darn near any application, pretty much universal.
Smoke Tires, not Drugs |
I used an F-body pan for mine.
the truck pan will work, but hangs down below the crossmember. |
The truck pan hangs down less than an inch with the ECE mounts.
Next project: 1970 K10
GM part number 19212593, universal oil pan kit, fits all Gen III and IV engines (not a direct fit for the LS7, LSA, and LS9) and includes the oil pan, gasket, indicator tube and indicator, pickup tube and crankshaft oil deflector.
$120.96.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-27-2010 at 02:52 PM. |
GM ONLY BABY!!!
I already have the ECE motor mounts and plan on using them, I also have air ride and my front crossmember is only 2" above ground aired out. Thanks guys!!!!
GM ONLY BABY!!!
If I change to a F body pan will the p/u tube also need to be changed?
yes, and windage tray, and dipstick.
On the fast track to nowhere..
+1
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
GM ONLY BABY!!!
cool thanks backyard88.
GM ONLY BABY!!!
Does this come with the oil cooler block off plate? Are you guys running an oil cooler? Is it needed?
Don't know if it comes with a block-off or not, but I put a corvette style adapter on there, and tapped it for a mechanical oil pressure gauge.
Mine came with the block off plate already on the pan. I don't see a need for an oil cooler on my application.
#15 |
I dont know the part number but its called the "LS SWAP OIL PAN" you can get it from Jegs, Summit or GM. It come with evey thing you need. Bolts, gasket, p/u tube and it does have a bolted on block off plate for the oil cooler. You shouldnt need an oil cooler unless your towing, or have a superchager/turbo on your motor. I also have the ECE motor mounts and it may hang 1/4" below the cross member but thats where the drain plug is. This pan is off an 08 Hummer H3. So thats the oil filter you need to ask for when you go to change your oil.
#16 | |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#17 |
GM ONLY BABY!!!
Yep, I ordered the GM 19212593 from www.gmpartsdirect.com the other day. It has shipped, so hope to have it Tuesday.
#18 |
GM ONLY BABY!!!
I assume that it's pretty accurate being that it is placed there? So, you are not using the electric gauge?
#19 |
GM ONLY BABY!!!
So what oil filter fits this pan? I already purchased a filter to fit the old pan. 01 6.0 LQ4 filter doesnt fit this pan. Another trip to the parts store with pan in hand.
#20 |
ACDelco PF-48
#21 |
I have the sender hooked up to the PCM (not that it's needed...), but am using a mechanical gauge for the cab. I don't see why it wouldn't be accurate in that spot.
#22 |
GM ONLY BABY!!!
Thanks Glock!! You are a Gentleman and a Scholar.
#23 | |
![]() Join Date: Apr 2005
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
| Bookmarks |
