Old 07-30-2010, 06:08 PM   #21
68 c10 ls2
68 c10 ls2's Avatar
Re: Which oil pan for 72 GMC 2wd?
I dont know the part number but its called the "LS SWAP OIL PAN" you can get it from Jegs, Summit or GM. It come with evey thing you need. Bolts, gasket, p/u tube and it does have a bolted on block off plate for the oil cooler. You shouldnt need an oil cooler unless your towing, or have a superchager/turbo on your motor. I also have the ECE motor mounts and it may hang 1/4" below the cross member but thats where the drain plug is. This pan is off an 08 Hummer H3. So thats the oil filter you need to ask for when you go to change your oil.
68 c10 ls2 is offline   Reply With Quote
