08-11-2010, 12:57 AM | #26 |
Re: New engine help
08-11-2010, 01:07 AM | #27 |
60-66 Nut
Re: New engine help
That I don't know, I've never bought a crate engine. I would think so though. Basically you will want to have the engine fire as soon as possible (no lengthy cranking) and run it @2000 rpm for 20-30 minutes, varying the rpms some intermittently. This will breakin the cam. You will want to be sure and use a breakin additive in the oil. Also since this is a flat tappet cam engine, you will need to either use an oil that has sufficient levels of ZDDP, or use regular oil with a ZDDP additive. This is to protect the cam and prevent premature cam failure. There is a sticky in the 'Engine and Drivetrain' section about proper oils.
08-11-2010, 01:12 AM | #28 | |
Re: New engine help
