![]() Join Date: Apr 2005
Re: Vent Window Rebuild or Replace
[quote=Ratone71;4135081]+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Sofa King Crazy!!
There is a step by step in the forum FAQs. Did mine and it was pretty easy. If you drill out every rivet it makes it much easier, you just have to keep the frame straight, it will bend easily.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
Rebuilding them is easy, as mentioned before, remove all the rivets, it makes the job much easier. I learned that it helps alot to lube the rubber that pops into the frame, the first time I rebuilt a pair I didn't think to lube the rubber and it was a pain in the anus! If you take your time they will look just as good as new. I used a rivet gun for the pivot.
![]() Join Date: Aug 2011
subscribed
