06-02-2003, 10:53 AM | #1 |
Thermostat Temp
Found that the thermostat in my truck was a 160 so replaced it with a 195. I have heard before that 190 or 195 is the optimum temperature because the oil is warmer and slicker and there is less wear. True?
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
06-02-2003, 11:06 AM | #2 |
I think the 190-195 is for later model engines but I am probably wrong.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
06-02-2003, 11:18 PM | #3 |
its all about the +6 inches
Some people believe that the condinsation evaporates better at about 200 degrees, and therefor a better temp to run.
I run 160 degree stat becouse my engine runs 10 times better at cooler temps, and my MPG goes up. |
06-03-2003, 09:06 AM | #4 |
now I know
06-03-2003, 09:27 AM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
GM spec's out the 195 in thier TPI+TBI vehicles.They designed the eng. to run in that temp. range.It's an ECM(computer) thing.
Heat does play a role but the major factor with how an oil flows is it's viscosity rateing. Of course a warm oil flows better than a cold one but how thick it is (viscosity) plays a role too.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
