WIW 71 2wd blazer
Im not sure if this is where this belongs, if not please move it. I am considering selling my factory 2wd blazer. It is a 71 on air bags (not plumbed but do have all fittings and lines to use shrader valves). The engine is an 01 5.3 (30K miles) with a comp big mutha thumpr cam, ls6 springs and it is tuned. It also has a 4l80e with a 2500 stall. The transmission is in but not fully installed. I have the shift linkage, flexplate and spacer to complete installation. It also has a new gas tank, walbro fuel pump, hooker headers, new brake booster, master cylinder, prop. valve,and rear disk brakes. I had started installing a step notch in the rear but so far I have only cut the floor to clear the notch (which I cut down to only raise the floor 4" so I could keep the rear seat), the frame is untouched. I have many new in the box parts including new autometer gauges in a new bezel, new rockers, rear floor section, rear cross brace, new tailgate, new rocker box for the drivers side, uncut ac dash, and im sure some other stuff. There is a little rust in the rear floor section and the drivers side floor which I had started to repair but never finished. I also have rack and pinion for a drop member I would include. Im not certain I want to sell it and have no idea what it would be worth. So what is it worth?
Re: WIW 71 2wd blazer
looks like a nice ride I would say any where from 45-6000 depends on the work done and parts like the Ls wiring ,seats,body panels.
That is about what I was thinking. I just cant bring myself to sell her. Ill put her in storage until im motivated to work on her again.
Hi, if the body's solid, let me know when you decide to sell. thanks, bye.
Body has a little rust but I have all patch panels to repair it. Let me know if you are interested.
Hi, I know about the a/c dash picture, but what are the rest of the pics?, also do you have any more pics?..... do you really want to sell? I might be interested if the price is right?,, thanks bye,
The other picture is some of the patch panels for it. Im going to try to get pictures today if I can find the camera.
Here are a few pics
few more
The motor is wired and has been reprogrammed for the cam. I have not reprogrammed it for the 4l80e. The seats are complete but need to be recovered. I also have a spare tire carrier I can throw in. I will sell all or part. I wouldnt mind keeping the motor and trans if someone wants the body and suspension. I also have 3 front crossmembers, 1 stock 1 sectioned, and custom built that needs to be finished. The custom one is similar to the original drop member. It still needs lower control arm mounts and mounts for the rack.
Hi, blazerboy72, what's the least you'd take for it as is?...... and price without motor/trans (body & susp.& parts only?..... Why are you selling?... thanks , bye... blue.
Im selling trying to fund a land purchase, and I dont have the time or money to finish the truck the way it should be done. I need $5500 for the complete project. $2500 for body and frame. $4500 with out motor and trans.
Hi, for $2500 exactly what would I get. also, can I get a ph. #,,,,,, thanks, bye .
Body with original hood and fenders, stock frame, rear axle, all 3 front crossmembers, and you can have the air bags and step notch which I cut down so I could still use a rear seat. I would keep all the aftermarket replacement parts.
#15 |
how much for the motor and trans? also interested in tank and fuel system for it.
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
#16 |
I would like to keep the engine and trans unless someone buys it all.
| Bookmarks |
