Old 07-27-2010, 09:26 AM   #76
nomrlz
nomrlz's Avatar
Re: C10Slim's 66 Build Thread
that's lookin nice. i've got several cans of easy off for when we do the frame on our truck
nomrlz is offline   Reply With Quote
Old 07-28-2010, 01:43 AM   #77
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Hey Slim, looking at the photos of your header instal, it almost looks to me like a header designed to fit a '68-'72 GM A-body (Chevelle, Cutlass, GTO, etc) would work good in there. Might this have been a design you tried in your previous attempts, or was it just different manufacturers of parts specifically for the '60-'66 pickups?
fryer1979 is offline   Reply With Quote
Old 07-28-2010, 11:16 AM   #78
C10Slim
Doug's list these headers for:
1967-74 Camaro
1968-74 Chevelle
1968-72 Chevy II, Nova
1968-74 El Camino
1965-70 Passenger Car, Wagon
1965-66 Chevy C10 (don't ask me why 65-66??)
The biggest issue was finding a header that would clear the CPP perches. The #1 tube dipped to low and would hit the driver side perch. First, I tried a set of Patriot ''Clippster'' Style headers, no where near right. Then I tried a set Hedman headers that were very close, but would not quite clear perches. I could probably have massaged them a bit or shaved the perch to fit. Then I saw these in the CCT mag article, had tons of room around the perch and were more of a long tube design (the others were shorty).
C10Slim is offline   Reply With Quote
Old 07-29-2010, 03:55 AM   #79
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Good to know, thank you.
Old 08-01-2010, 10:04 PM   #80
C10Slim
Getting closer to start... The brakes are completely juiced and ready to go now. Gas pedal is installed and hooked up. Radiator and trans cooler mounted. Started running the trans lines but need a few more clamps to finish it up.
Old 08-05-2010, 10:33 PM   #81
C10Slim
Cooling system is done! All trans and rad lines plumbed, fan and shroud mounted, ready to go!
Old 08-16-2010, 08:40 PM   #82
C10Slim
Steering column, steering wheel and gauges ready to go. Going to wire the truck up this weekend I hope.
Old 08-16-2010, 09:05 PM   #83
CVA59
Got any more pics? that is looking great Slim. What are the details on the Rad and shroud you are using?
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 08-16-2010, 09:15 PM   #84
C10Slim
Thanks. More pics to come. Radiator is a dual core 1" tubes off of ebay, the fan is a Zirgo 3000cfm and the shroud was made by us radiator.
Old 08-16-2010, 09:24 PM   #85
CVA59
Thanks for the info, it sure looks like it all fits really good. Nice and clean.
Zack
www.23t.weebly.com
Old 08-16-2010, 10:36 PM   #86
SCOTI
SCOTI's Avatar
Do those alum gauge panels simply swap in place of the OE clear lens? Do they have all the standard OE 'locating' holes for the outer cluster housing?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-16-2010, 10:44 PM   #87
C10Slim
Yep:
Old 08-16-2010, 11:18 PM   #88
SCOTI
SCOTI's Avatar
What manufacturers panel is that?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-17-2010, 01:26 AM   #89
C10Slim
Boese Engineering I picked it up from thier ebay store.
Old 08-22-2010, 08:12 PM   #90
C10Slim
This week end I got the new custom 1 piece driveshaft is in, Front clip back on, and started the wiring and dynamat. Big thanks to my bud Brian for crawling in to the engine bay and doing most of the work in there.
Old 08-22-2010, 08:14 PM   #91
C10Slim
more pics...
Old 08-22-2010, 08:17 PM   #92
C10Slim
Few more
Old 08-27-2010, 02:14 PM   #93
firefighter736
firefighter736's Avatar
I LOVE this build, man.
firefighter736 is offline   Reply With Quote
Old 08-27-2010, 04:30 PM   #94
CVA59
Looking good!!
Zack
www.23t.weebly.com
Old 09-05-2010, 03:17 PM   #95
C10Slim
Started the beast the first time today!!
Old 09-06-2010, 12:57 AM   #96
Captainfab
60-66 Nut
That sounds good
Old 09-07-2010, 10:35 PM   #97
likaroc13
Rollin' Old Skool
sounds great!
Old 09-08-2010, 09:48 AM   #98
DPowers
One foot in front of the other
DPowers's Avatar
Truck is looking great-
DPowers is offline   Reply With Quote
Old 09-08-2010, 12:55 PM   #99
dean jendro
Old and crusty
dean jendro's Avatar
Sounds very gnarly!! Your build is coming along very nicely.
dean jendro is offline   Reply With Quote
Old 09-16-2010, 12:31 AM   #100
apachedaddy
apachedaddy's Avatar
Could you give me some info on your steering column and wheel. Part numbers/IDIDIT??/dealer/ is it a retro fix column? Was looking at the IDIDIT colums from summit and wanted to see if there others out there that may be cheaper is all. Thanks for any info you might have for me.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
