10-07-2008, 08:09 AM | #1 |
Junior Member
lets see some bagged c10s
thinking bout baggin my 60. also is it a pain in the A$$ to do?
1968 chevelle ss 396 4spd 1969 chevy 4wd 350 4spd 1970 chevy c10 long box 1970 GMC 4wd long box |
10-07-2008, 02:34 PM | #2 |
It's Better With Nitro
Re: lets see some bagged c10s
Here's what mine looked like just after I finished the front and rear suspension. This is at full drop (resting on the stops, so I can drive it in case there is a problem with the air bags).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-07-2008, 04:37 PM | #3 |
heres mine..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
10-07-2008, 07:47 PM | #4 |
10-07-2008, 09:44 PM | #5 |
10-07-2008, 09:48 PM | #6 |
Here's mine, horrible pic... Still had exhaust underneath body. Now is in a million pieces again getting front end z'd then onto backhalf
10-07-2008, 11:19 PM | #7 |
Mine-
bagged the first time Bed has no wood so it sits lower Stuffing 29" tall tire! Lose the stock trailing arms, they are WAY more of a pain in the butt to work with then they are worth! This is the frame clip I made to clear them, I ended up cutting the whole rear of the truck off.... and you have to also remember to shave or remake the crossmember for the driveshaft... Cutting off the rear clip progressed to crewcabbing it... and here is where it sits now, back on the ground with the damn driveshaft crossmember holding it up again! If you have any questions, PM me or ask them here, I'll tell you all I know and what to look out for! |
10-10-2008, 12:49 AM | #8 |
Junior Member
i am thinking about doing it to my truck. did you guys buy a kit or build the air system? is it possable to not have to do any notching?
10-10-2008, 01:03 AM | #9 |
I used to run mine w/o a notch. Just don't expect a ton of drop. Atleast c notch it. Those are pretty simple and don't go all the way through the frame, but their also not as low. I bought a kit, but next time I would either talk w/ a shop and have them custom do kit to what I need, or piece something together.
10-10-2008, 07:19 AM | #10 | |
10-12-2008, 09:22 PM | #11 |
it is a pain!!!!! heads up order a straight notch due to the torsion x member the 63-72 wont work and depending on the size tires u want to run u may have to step it up. for the front is straight forward with a suicide doors member or porterbuilt good luck with the adventure
making trucks pointless 1 at a time |
10-12-2008, 09:33 PM | #12 |
Needs a Big Block
Heres my ole heap...
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
11-20-2008, 12:54 PM | #13 |
11-21-2008, 12:44 AM | #14 |
yes sr. it is a lot of work especially working with a torsion bar frame
11-21-2008, 09:56 AM | #15 | |
Hollister, CA.
Although, I think the stock "nascar" style trailing arms work great...no axle wrap and all you need is a sweet Watts link and your good to go !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-21-2008, 11:08 AM | #16 |
One day...
Mine. Getting there slowly, have to finish up the link arms in the back.
11-21-2008, 04:48 PM | #17 |
looks like a stock step side bumper
CHEVY ONLY |
11-21-2008, 09:12 PM | #18 |
100% gearhead
Here's my pile. '62 with a pretty simple set-up.
11-21-2008, 10:22 PM | #19 |
Stirrer of the Pot
hey imperial, do you have more pics of the bd work? that's a great lookin' ride. I'd like to see the inside of the bed too.
12-14-2008, 04:31 AM | #20 |
1963 chevy truck
09-02-2010, 07:01 PM | #21 |
here's my 65' C-10
