"something witty here"
big block in a 57 ???
Is it possible to put a bbc into a 57 3100 with out any mods to the firewall? Or am I SOL and stuck with a sbc.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
Re: big block in a 57 ???
The firewall shouldn't be an issue. Remember, the engine compartnment is long enough for an inline 6. Now as far as steering, exhaust, and other fun stuff like that, you are on your own.
Ray |
Im hoping to swap to power steering from a 70's k10 so that shouldnt be a problem, and Im sure that there is headers out there that will work. I was just worried, when I look at my 2ton with a 283 and thought it looked pretty snug in there. Its going in a 4x4 if that makes any difference...
Ok, I made an assumption that maybe I shouldn't have.
If you are running a manual transmission, and the bellhousing is sitting on the stock crossmember, it's not going to work. You will have to move the engine forward. Ray Last edited by raycow; 09-03-2010 at 01:02 AM. |
Im also swapping in either a th350/np205 or 700r4/np241 so the stock crossmember will be gone, I also have a tubular universal engine crossmember I will use...
I put a 500 Cad with matching transmission in a 59 ton and a half. Tight
fit, the only mod was using the original transmission mount and moving it forward some. As you know the cab is the same, but the fenders are a few inches longer. Don't know if you have the room, length wise or not. Good luck |
I,ve got a Big Block in a '56 ,should be the same. Sanderson makes headers for these trucks.
Here's a 572 in a '55.2nd
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
| Bookmarks |
