Old 09-19-2010, 02:52 PM   #1
BlueMagicSS
Lift Kit Questions
I know this is more of an opinion but I've been looking and need a little help.
I'm planning on doing a lift on my 89 K5 and I want to know which is the best kit. I'm looking for a more streetable kit as I won't be doing too much off-road, more of looks. I'll probably tow my car to the track or a boat a little later on, but looking for more of a comfortable ride. I know that it won't be stock because of the changes, but what would you suggest?
I want Leaf Springs in the rear not blocks or add-a-leafs. Dual steering stabilizer and a decent ride. I've looked at all the kits on rockymountainsusp.com and say that the 6" Kits clear 37's. I thought that 6" would only clear 35's? or does it depend on the kit? Also which upgrades would you suggest at the same time? Thanks
Matt
BlueMagicSS is offline   Reply With Quote
Old 09-19-2010, 03:49 PM   #2
shovelbill
Re: Lift Kit Questions
2.5" and some trimming clear 35's just fine.....why do you want to be that tall to tow with? you'll need to re-gear it, address steering and braking too. you'll most likely want a semi floating 14 bolt to tow with also. with that tranny 4.56 gears would probably be a good "decent" stocklike ratio depending on the weight of your loaded trailer and terrain.
i'm going with 3" tuff country springs, good shocks and 33's to keep it simple, i have 3.73's...but i'm not towing. the closer to stock you stay the easier and cheaper it'll be.
shovelbill is offline   Reply With Quote
Old 09-19-2010, 07:40 PM   #3
russgt
russgt's Avatar
check out off road design, running a shackle flip in the rear with stock springs is suppose to ride better than just a spring lift. i have also heard good things about EZ rides (tuff country I think) for the front.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 09-19-2010, 08:28 PM   #4
shovelbill
yup.....this is the kit/setup i was looking at too. give them a call.
http://www.offroaddesign.com/catalog...liftsystem.htm
Old 09-20-2010, 02:34 AM   #5
BlueMagicSS
My main goal isn't to tow, more of a looks mod than anything. But 4-6" will be good for me. and I currently have 3.73's in my rear now because I replaced the rear after it went bad on me a few years ago. My tires are 31/10.50's currently though
Old 09-20-2010, 06:53 PM   #6
russgt
russgt's Avatar
unless you have a lot of HP/torque, you will hate 3.73s with 35s. I would suggest at least a 4.10 gear.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 09-20-2010, 07:37 PM   #7
BlueMagicSS
Seems like I'll be swapping them out too... I already need to swap out the front end gears so may as well do both when the time comes... At least the bearings will be fresh.
Old 09-29-2010, 01:29 PM   #8
sandnuriz
sandnuriz's Avatar
Hit these guys up they are great no BS....................http://www.4wheelparts.com/?utm_sour...FQwTbAod_XK3ag
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
