found drivers door
Well drove out to the sticks this weekend to pick up a replacement door for my 76....it turned out to be in great shape and rust free. one large dent that popped right out once i pulled the door panel.
![]() not bad for $50! only prob. is there are mounting holes for the door panel that i will have to fix now....(marked in red) ![]() i want to stick with the 76 panels i have.....here is my original door ![]() or i can just go with the larger door paneling but i like the older ones? thoughts?
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
Re: found drivers door
Never paid that much attention to how much door was being covered up over the years as the door panels changed. Now you can't even tell what color the door is painted except in the jams
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 09-27-2010 at 02:57 PM. |
yeller
You will have to change more than that...the window regulators are different, window tracks the rollers slide in are different...you can't put 73-76 guts in a 77-87 door without modifying other things.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
bigblock73- what about just the interior door panel??? thats all im looking to put on?
yeller
You just want to put on the door, and install your 73-76 door panel right? If so, then the window crank will sit further from the door panel and it won't be flush (the shaft is longer on the newer doors vs the older doors). Does it affect the functionality...no, but it may look a bit odd. You may also need to change out the inside door handle...not sure if they changed with the door panels.
| Bookmarks |
