Old 09-27-2010, 01:54 AM   #1
Wet..Paint
anybody run a 10" wide wheel with a 7" drop?
hey just wondering if anyone on here has a 7" drop in the rear of their truck and running a 10" wide wheel, what size offset do you have? what size tire are you using as well?
I want a wider tire but the sidewall is pretty close to the lip of the wheel well, looks like theres a couple inches to go before rubbing the leafs. so to go wider would be more offset? I was thinking of mini tubbing the box to get more room but seems like a lot of offset for a rim?
any pics?
Wet..Paint is offline   Reply With Quote
Old 09-28-2010, 01:17 AM   #2
Wet..Paint
Re: anybody run a 10" wide wheel with a 7" drop?
after hours of searching i found a 15x10 will work with atleast 4.5" backspace, im gonna go with 5" backspace so i can mini tub the box a bit and get the biggest tire in there possible.. anyone know what it would be? i'll have to get the rim and measure it out one the truck
Old 09-28-2010, 02:19 AM   #3
3r!c84
Badass
3r!c84's Avatar
15x10 rally?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-28-2010, 10:07 AM   #4
Wet..Paint
i search lots more last night and found wheel vintiques makes a 15x10 rally with a 5" backspace so thats what i'll be going with
Old 09-28-2010, 11:23 AM   #5
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
here are some wheel vintique rallies, 15x10 with 5'' of b/s. the drop is about 6.5, running a 295/50r15 at the time.
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 09-28-2010, 11:24 AM   #6
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
sorry , the lower pic is the one with th lower drop, i accidently added the first one.
Old 09-28-2010, 03:06 PM   #7
Wet..Paint
that looks good thanks! Does it stick out any farther than a stock 8" rally wheel? Thats my main concern because the 8" with the tire i have on its very close to the inner lip of the wheel well but if i need to ill just trim it off
thanks again
Old 09-28-2010, 03:08 PM   #8
3r!c84
Badass
3r!c84's Avatar
My back tires stick in alot more then the front
-00 Saturn 5spd
1/4:13:90
Old 09-28-2010, 05:15 PM   #9
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
thanks again
thanks, my front wheels are 8'' with 4''s of b/s, they are flush with the rear 10'' wide wheels. thats why i got 10''s with 5''s of bs on the rear, to make up for the whole track width thing, they sit just inside the fender. i can squeeze in about a fender
Old 09-28-2010, 09:12 PM   #10
Wet..Paint
awesome thanks! what about to the leaf springs? any idea how close they are? or how close the tire is to the inner wheel tub?
Old 09-28-2010, 11:33 PM   #11
SCOTI
SCOTI's Avatar
My 74 has a flip-kit w/some drop shackles on the 8-leaf spring pack. I've ran 2 different 10" width wheels in the rear. I had 20x10" w/5.00bs & 295-40's & 20x10's w/5.50bs & 295-40's.
Although both physically fit, the 5.00bs offered better clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-29-2010, 12:26 PM   #12
Puglia10
in for the same info, thanks
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
