Old 10-06-2010, 04:59 PM   #1
82swampthing
82swampthing's Avatar
passenger door won't unlock
hey guys the door on my passenger side won't unlock it will lock though.I pulled the asembly out and I can't seem to figure out why it won't unlock by it self.If I move the arm atached to the claw I can unlock it ,but if pull on the rod to unlock it ,it does nothing.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 10-06-2010, 05:13 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: passenger door won't unlock
First impression would tell me the latch is borked. If none of the linkage is in a bind and can be moved freely, then it'd almost have to be the latch.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-06-2010, 05:14 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
could the push button be sticking on the outside,seen it up here cold and rusty the button outside sticks in a bit.push lock down and push outside button to loosen,then try unlock
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-06-2010, 05:26 PM   #4
82swampthing
I have the entire latch out ans on the bench.when it was in the door you could move the lock a little bit but it felt like it was jammed .just to get the door open I had to use pliers on the key to force it open so I could get the door open to take the panel off.I almost ripped the lock cylinder out of the door.the button on the outside works fine so does the handle inside.It was working fine when I changed the lock cylinders and for some reason now it doesn't want to unlock.
R.I.P gm 1908-1986
Old 10-06-2010, 07:00 PM   #5
82swampthing
I got it ,just needed alot of wd-40 where would I be without that stuff
R.I.P gm 1908-1986
Old 10-06-2010, 07:03 PM   #6
54Caddy
GM Addicted
54Caddy's Avatar
lithium white grease would be better. The wd40 will not lube as long
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 10-06-2010, 07:21 PM   #7
82swampthing
I'll put some on it but it doesn't pentrate rust as well as wd-40,but I will put some on after I get it back in.Thanks for the replies guys
R.I.P gm 1908-1986
Old 10-06-2010, 07:25 PM   #8
irishman999
irishman999's Avatar
You beat me to it, my 85 had the same exact problem. The only difference is I used PB blaster.
irishman999 is offline   Reply With Quote
Old 10-06-2010, 07:34 PM   #9
82swampthing
pb blaster is even better,but I don't have any right now just ran out.You know what works better than both ,marvel mystery oil in a spray bottle
R.I.P gm 1908-1986
Old 10-07-2010, 04:03 AM   #10
irishman999
That oil is awesome, If you use that crap in your air tools they will last for ever. I used this crap once at a power plant called AreoKroil or something like that, It came in a orange can and was actually better than PB blaster.
