Old 10-12-2010, 04:03 PM   #1
irishman999
irishman999's Avatar
Re: QJet Adjustments
Originally Posted by Mattman2010 View Post
It was in the closer hole, and I moved that to the farther hole and it doesnt seem to have made a difference.
I know my engine is burning oil, so at start up there is some black smoke. At times I think that there is some black smoke but it just isn't enough to really tell. The secondaries are just floating, they do not have that vacuum operated linkage hooked up to them. The PO took it off because he said that they go bad and it works without it. I have the vacuum thing, but I do not have the actual linkage that goes between that and the secondaries. Could this be the problem?
The carb is the original one to the truck that I know of. I pulled this engine and carb out of a K20 that was all rusted, and put it in my k10.
If its burning oil the smoke should be a white/blue color, black=rich. Try connecting that vacuum pull off, That will keep the secondaries from flapping open before the vacuum condition is right.
When those secondaries open it pulls some needles out of the big secondary jets that dump fuel down your carburator.
I have to warn you that this is my theory, I am not an expert and there is most likely 100's of people here who are experts.
irishman999 is offline   Reply With Quote
Old 10-12-2010, 05:28 PM   #2
Mattman2010
Mattman2010's Avatar
Yeah after I said that I was talking to my dad he said oil is blue, water is white, and rich is black. When I floor it i do get black smoke, so it is getting to much fuel at full throttle. The vacuum thing would be a simple fix, but I am missing the linkage that goes from the vacuum to the secondaries and I am not sure where to get that from.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 10-12-2010, 05:38 PM   #3
irishman999
Go to a pick-n-pull, Im sure there is at least one qjet you could snag the linkage and vacuum part off of.
