#1 | ||
Re: QJet Adjustments
The carb is the original one to the truck that I know of. I pulled this engine and carb out of a K20 that was all rusted, and put it in my k10.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
When your truck is warmed up, remove the air cleaner and operate the throttle to simulate condition you describe above. On two of my squares, the Qjets had a sticky choke valve, causing the engine to bog and consume a lot of gas. These choke valves and associated linkage have a tendency to carbon up and stick. I had an Edelbrock that had a choke valve that was manufactured slightly too big for the opening in the carb - I had to remove the valve and file it off slightly - then the choke would never close off completely and caused hard cold starts.
#3 | |
When those secondaries open it pulls some needles out of the big secondary jets that dump fuel down your carburator. I have to warn you that this is my theory, I am not an expert and there is most likely 100's of people here who are experts. |
#4 | |
#5 | |
