#26 | |
Re: Crate Engines
Of course you need an efi fuel system w/return ... I had to add a return line to my aluminum rear tank as well as provide the fuel lines to and from. They provided an electric pump. My old dizzy was hei, so I now have to provide a coil. I wasn't going to screw with things by trying to substitute my old HEI. It seems to be pretty complete as of this time, with the exception of the above noted items. More stuff will probably come up as the install progresses .... it always happens that way. Not sure how much longer their introductory deal will be running. Barry
Barry L. Van Hook '69 Chevy Frankentruck |
#27 | |
Re: Crate Engines
Ray 1971 Cheyenne LWB 1965 C-10 Short Fleetside 350/350 2010 Harley Davidson FLHTK Last edited by repeeler; 10-31-2010 at 10:46 AM. |
#28 |
Re: Crate Engines
Thats a great price on a 383 fuel injected complete engine... Up here just the long block is more than that. Too bad Im already setup or there would be one in transit.
67- 72 Parts collecter |
#29 | |
Re: Crate Engines
I'm using my 700R4 and only had it upgraded with new clutchpack and no shift kit ... and added a new converter with stock stall. Seemed to be right for a cruiser. I don't know why the 350 wouldn't work, but an o/d might improve the mpg somewhat. I've heard of stock tanks being converted to efi w/return lines, but I'm unfamilar with the particulars ... I recall others on this forum have done it. Your questions are typical of the "while I'm in there" syndrome that I'm struggling with? ![]() Good luck from one bagger owner (Y2K FLHT) to another! Keep us posted. Barry
#30 | |
Re: Crate Engines
Ray 1971 Cheyenne LWB 1965 C-10 Short Fleetside 350/350 2010 Harley Davidson FLHTK |
#31 | |
Re: Crate Engines
Barry
#32 |
Re: Crate Engines
I got a GM crate motor years ago and it was great....and the pricing is real good too.
#33 |
sharp as a marble
![]() Join Date: Jan 2007
Re: Crate Engines
I have bought two GM crate motors. ZZ502, and 330hp sb. I love the big block! for a short drive. The small block I can drive for hours. I am the care taker for a LS2 supercharged 57 Chevy, and a ramjet502 in a 56 Buick. If I have learned anything, I am a proponent of the KISS method. Make SOME power, and keep it simple. Long term you will drive it more and enjoy it a TON more!
