#101 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I've actually thought about doing a steel inner if I did this project. I wonder if you could take another roof skin from another burb, or the left over from the rear of the cut off area that is not used at all, trim it down and use it? Maybe put some bows in there first, tack them to the outer skin and the inner top of the burb roof to cab framing. Then place the trimmed burb roof skin in and pre drill some holes to be able to spot weld to the bows. This would be real easy to do if you have a way to stand the cab up on its back or flip it on its side I think. IDK, just some ideas I have been tossing around.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#102 |
TNT-MOTORSPORTS
Just a thought ..... How about the inner skin out of a newer crew cab ???
#103 | |
Still plays with trucks
A traditional vinyl one with bows like a 60's car used would be easiest. Just bend up some 1/4" rod to the contour you want and mount them with clips in the center and receiver pockets on the edges to hold them in place. Hand it off to an upholstery shop and let them have at it. The edge trim may take a little work but nowhere near what the smooth headliners would take. The upholstery shop could probably take care of the edge trim too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#104 | |
![]() I think the newer cab is a bit wider at the top but it would be a good place to start. A little sectioning and welding and it could work out pretty well with a whole lot less work than fabricating one from scratch.
#105 |
Personally, I'd either want a steel inner of go the fiberglass route. My friend had a 48 Chevy the size of a crew cab but only a 2 door. He had an old style cloth and bow headliner in it once. It just looked out of place so he built a fiberglass one. That was the ticket! 5 years later he built another one and this time he did steel. That was even better IMO.
#106 |
67cheby
![]() Join Date: Sep 2008
why not just weld a couple of reg cab inner roof panels together and make it look like it was made that way ??
#107 |
TNT-MOTORSPORTS
#108 |
That is a good idea too. It would be a lot of cutting and welding, but I guess that is the whole project.
#109 |
67cheby
i think it would be a lot more "impressive" and look like it is done right !! i saw an extended cab 68 done like this prob 15 years ago , and i still remember that trucks headliner today !!
#110 |
It would be a whole lot easier to find a few regular cab roof sections than it would to snag one crew cab roof too.
#111 |
WOW you have some balls,the truck was nice to start with and you are doing a great job.not just anybody can cut up a truck,keep up the good,no I mean great job.
big old burb in primer.lot of work to do. |
#112 |
I am completely blown out of my socks by this build. My hats off to you and I dont take my hat off for anyone. Its refreshing to see new ideas coming to fruition. GREAT JOB.
JRBECK64 |
#113 | |
Lucky Teter at the wheel
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#114 |
What do you think about getting a Headliner out of a new model Tahoe or Suburban? I dont know what the size of your roof is, but if the headliner was to big it would be easy to cut and glue back together.... Then you have a foundation for you fiberglass work.... Should be able to soak the headliner with resin and harden it. You might still want to use some fiberglass mat to reinforce it some.
Just an idea...
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
#115 | |
#116 |
Junk Yartist
my suggestion is a 1992-2000 chevy crew cab headliner if you are going to put in a headliner. it has a low roofline and simple curves. otherwise, what about using several inner roof pieces from a truck and then covering them with material? It wouldnt be removeable though.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#117 |
![]() Join Date: Apr 2005
That's how mine was done. here's a couple of pictures:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-06-2010 at 08:55 AM. |
#118 |
TNT-MOTORSPORTS
We have a winner ... That's the way I would do mine. Then maybe add a super headliner ....!!
#119 |
67cheby
That looks killer, imho that is the only thing that looks right !! Nice job by the way
#120 |
Thanks. Drew, have you started on your chassis yet? If you have questions, give me a call.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#121 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I like the steel headliner idea looks factory..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#122 | ||
#123 |
67cheby
the headliner would be the support you need that would take the place of the bow your talking about
#124 |
![]() ![]() Join Date: Jul 2002
Beautiful work so far. I am really enjoying your build.
#125 |
Remember the 100 dollar cabs I got? Well they came with doors too which I need to steal something off of. Measured 3 or 4 times on the drivers side only to cut it an eighth inch too short. DOH!!! Some surgeon I am. Passenger side I drilled out the spot welds and removed a good bit into the door. I'll just plug weld the holes at the bottom and butt weld at the top frame.
