Old 11-09-2010, 11:55 PM   #1
dbmx66
anyway to separate inner and outer bedsides?
on a shortbed? thanks
dbmx66 is offline   Reply With Quote
Old 11-10-2010, 08:11 AM   #2
xrcr
Re: anyway to separate inner and outer bedsides?
Can't you un bolt them?
xrcr is offline   Reply With Quote
Old 11-10-2010, 08:15 AM   #3
big10ratrod77
big10ratrod77's Avatar
im perty sure they are bolt on cept for one tack weld neer the front i think
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 11-10-2010, 08:24 AM   #4
MONTEZ
I think the inner skin is spot welded to the outer skin.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 11-10-2010, 01:12 PM   #5
hugger6933
drill out the spot welds then take a flat bar and work your way down the seam. If you are not trying to save the outer panel you can grind thru the welds with a die or angle grinder. I have replaced bed 'skins' many time on the 88-98 trucks and several on the 07 and newer body styles. it is a pretty easy job but it is labor intensive. But on these olds trucks that we treasure so much is'nt it all? Jim
hugger6933 is offline   Reply With Quote
Old 11-10-2010, 10:51 PM   #6
dbmx66
im trying to eliminate the inner beside, but keep the outer
Old 11-11-2010, 02:05 AM   #7
big_b
like mentioned above the inner is spot welded to the outer. youll have to drill out the spot weld or cut at the seams with a cut off wheel if you want to remove them.
the box is basically held together by the inners bolted to the bed floor, bulkhead etc. how are you going to bolt it all back together if you cut the structure out?
big_b is offline   Reply With Quote
Old 11-11-2010, 04:49 PM   #8
dbmx66
welding 2x2 square tubing supports with 1/4 turn fasteners, out skin by its self should be light enough to use them.
Old 11-11-2010, 06:17 PM   #9
hugger6933
Instead of seperating the two, have you considered just cutting out what you don't want ? That would be the easiest way to go and that way you would have the double wall to weld your tubing to and that will weld easier. Jim
