Old 06-14-2003, 11:44 AM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
Gas pedal hard to push
Ever since I bought my truck my Gas pedal has been really stiff. Even after I replaced the throttle cable its still stiff. It doesn't normally bother me but since I have to drive so far to work and my cruise control doesn't work I'm just getting tired of the pedal being so stiff. It really sucks sometimes because the way you have to push it is all or nothing. Any ideas why its so stiff?
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 06-14-2003, 12:01 PM   #2
ocbaud
Garage Queen Material
you need leg muscles:p
ocbaud is offline   Reply With Quote
Old 06-14-2003, 12:07 PM   #3
messed up c-10
RHCP afficianado
I got them. It sucked though after driving car for two months thats fine then switching back to this. It took awhile to build that right leg back up.
~Ryan~
Jack Johnson
Old 06-14-2003, 01:02 PM   #4
85 K5
Disconnect the TV cable (assuming you have the 700R4) and try. Every little thing helps. Disassemble and clean the pedal assembly inside the cab, replace the cable or lubricate, lube the tv cable and spray carb cleaner on the linkages. It will still be stiff but slightly more tolerable.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 06-14-2003, 02:58 PM   #5
bigd65
bigd65's Avatar
you probably have a EDDY 1406 and have the double return spring
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 06-14-2003, 03:03 PM   #6
messed up c-10
RHCP afficianado
The throttle kit came with two springs but we had to take one of them off because with both of them on there the only way to push the pedal down was to stand on it. So now I just have one spring. When I was working on my q-jet I didn't have the spring connected and the pedal felt great but when I put it back on it got alot tighter.Would shortening the throttle cable so that there isn't as much slack help out alot.
~Ryan~
Jack Johnson
Old 06-14-2003, 04:47 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
try eplacing the throttle return spring sometimes they are too small and make it harder to push
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-14-2003, 05:43 PM   #8
2tankin79
2tankin79's Avatar
i've got this same problem, and i have double springs on the edelbrock, it was all or nothing, and i only have my permit, so my parents have to ride with me all the time, and they would always say, "What was that for?!" when i'd hit the gas because it was so hard to push down, and it'd go all the way to the floor once i did get it pushed down, what i did to help out a little (but not much) was strech the springs a little so it wouldnt be so stiff, this only helped a little.. i hate having this problem though, and know what you mean..
2tankin79 is offline   Reply With Quote
Old 06-15-2003, 02:42 AM   #9
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I had the same prob with the POS 1406 edelbrock. It was new out of the box and did this. I put some oring lube on the black nub that I assume is for the fuel pump that is in the carb. This worked for me. I will never buy one again as they are JUNK in my opinion. Just me though so no comments please!! Great for cheap replacment part but not a performance piece.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 06-19-2003, 08:57 PM   #10
messed up c-10
RHCP afficianado
Hey I streched out the spring and its alot easier now. I also had to buy a new throttle cable so that might have helped too.
~Ryan~
Jack Johnson
Old 06-19-2003, 09:15 PM   #11
Russell
Professional Grade
Russell's Avatar
lol, anyone know why my brakes would be insanely stiff? I push on them and they brake NOW, instant lockup without putting them all the way down... Now, I am not complaining too much, better than none :p But it would be nice to soften em' up a bit...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-19-2003, 10:27 PM   #12
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
regarding the stiff throttle, I have a new cable and it was real stiff out of the box.. so I took a can of lithium grease (spray can) and sprayed some into the cable sheath then used compressed air to force it all the way thru the sheath.. it helped a lot .. in fact its about ready for it again..
btw, the factory double throttle spring is superior to others.. I dont know why you guys are dissin it..
mike
mike reeh is offline   Reply With Quote
