Old 11-25-2010, 05:18 PM   #1
SCOTI
SCOTI's Avatar
Ride Tech C10 Strong Arm Question
Ok here's a goofy one.... When installing the Ride Tech front C10 Strong Arms (1st series of arms), does it matter what the top/bottom orientation of the arms are? If you look @ them, they can be flipped either way & will work on either side. I'm just wondering if one way is correct/better?
The BJ flange would either be slightly above or below the a-arm tube depending on how they're installed. I never really gave it much thought before & as I was prepping everything for the 64, I started wondering if anyone else thought about it.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-25-2010, 09:35 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Ride Tech C10 Strong Arm Question
I never even notice this on the upper arms.
I thought the upper balljoint flange would have some built-in angle to it, to eliminate BJ bind at full drop.
But I agree,... it looks like they can be installed either way.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 11-25-2010, 09:44 PM   #3
lolife99
lolife99's Avatar
Would the balljoint flange contact the spindle at full dump, if these were turned upside down?
(and obviously swapped to the other side)
Keith
Old 11-26-2010, 11:16 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Mine came with stickers on them designating the correct way to install them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-26-2010, 12:06 PM   #5
SCOTI
SCOTI's Avatar
I had them both ways & didn't note any interference. That's kind of what got me thinking about 'how should they be installed' vs. how they 'look' the best to me installed. My thoughts were to install them so the upper/lower are as close to parrallel to each other as possible. Looking @ the BJ flange, you could see where there could be the diameter of the 'tube' difference which may/may-not help w/BJ binding if it came close.
Thanks for the pics Ken.... I'll look & see if that's how I had them (I can't remember @ the moment).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-26-2010, 03:12 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Looking at the pics, it appears the bj is set in upside down. I will verify with pics later
Old 11-26-2010, 06:08 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Installed...
Articles-
"Refining Sierra"
