ebay heads?
http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories What do you think?
Re: ebay heads?
Someone on here might know of them. But at least Patriot gives you flow numbers and are at a decent price.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Re: ebay heads?
I dont no much about about heads and stuff but it says it can go up to .600 lift does that mean i can get a cam with .600 intake lift? i kinda have my eye on this cam http://www.compcams.com/Company/CC/c...csid=1259&sb=0
Champagne Taste on Beer Budget
Re: ebay heads?
Yeah and for that price you could go (dare I say it) Pro Comp Aluminum heads.
And yes I would have to agree that the Patriot or other name brands would be a better heads than what these are.
Coming Soon: Project 1970 Country Truck |
Re: ebay heads?
Ok sounds good i think ima go with these unless they are to big? and what is the combustion chamber what is the difference between 64cc and 72cc?
http://cgi.ebay.com/ebaymotors/Patri...Q5fAccessories |
Re: ebay heads?
All things being equal a smaller chamber is better. For a given piston the smaller chamber will increase compression ratio. Most piston mfgrs wil give you compression ratios for both chamber sizes
Project Bad Karma |
Truck and auto performance nut
Re: ebay heads?
I agree.....I wouldn't pay that for iron heads when you can get aluminum heads for the same price or a little more depending on brand. Do a ebay search on sbc aluminum heads...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: ebay heads?
Well you guys no alot more about this stuff than i do so im trying to get about 400-450 hp with just changing the cam and heads my budget is about 1000. Right now i have a 355 with flat top pistons not sure what kind they have two valve reliefs a r/v cam and stock heads. If you guy could give me some ideas i would appreciate it.
60-66 Nut
Re: ebay heads?
I don't think you're going to be able to get 400-450hp for $1000 without adding some N2O.....even then.
Re: ebay heads?
for 400hp you can get a set of vortec heads and a cam and be just under $1000. 450hp, not likely. it would be better to spend the grand on a good set of heads and get the cam later, or save a little more and get a great set of heads for another 400 or so. I got my AFR 195cc heads from summit for 1400. Those heads with a flat tappet cam on a 355 will make 440 hp. 480 in a 383.
Project Bad Karma |
#11 | |
![]() Quote:
I'll bet those suckers flow great. Never heard a bad word spoken about AFR heads.
Re: ebay heads?
.490. Here is the link from Summit: CompCams XE274H, as shown in the August 2010 issue of Super Chevy. The 355 made 441hp @ 5900 and 438lb-ft @ 4500. The 383 (which I'm building) made 480hp @ 5700 and 495lb-ft @ 4300.
The 355 had flat tops with 2 valve reliefs and 10.2 compression. The 383 was -9.8cc dished with the same compression.
Project Bad Karma Last edited by pockets; 10-01-2010 at 11:18 AM. |
Re: ebay heads?
There was another 383 I was considering that was built up a few years ago that used powerhouse heads that made 425, so figure 385 or so on a 355 engine. Google Shoe String Stroker and you will find it on their website.
I ultimately went with AFR even though my cam isn't all that big because I can upgrade the cam later if desired and I know the heads will support it.
Project Bad Karma |
Re: ebay heads?
Those patriot heads are good BUT you need at least a 400+ inch engine because the 2.08 valve isnt going to flow as good as a smaller valve in a 350+ will. Its called valve shrouding. Patriot makes an excellent steel head (vortec) that I bought and they were 485 shipped without springs and keepers. In my opinion I think a 2.08 valve on a street 383 is too big and the runner volumn is going to kill low end. Heres my head numbers
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#15 |
Re: ebay heads?
just for comparison, here is the flow numbers for the AFR 195cc Eliminator head which has 2.05" intakes. The AFR comp head has 2.08.
Project Bad Karma |
#16 |
![]() Join Date: Jul 2008
Re: ebay heads?
Buy them and find a big ditch and throw them!!!!!!!!!!!
Built chevy tuff! ![]() |
#17 |
Re: ebay heads?
Also, don't just look at airflow. You need to look at air flow, valve diameter, and runner size. Too big of a valve and runner will slow the speed of the air down, resulting in less cyl fill (meaning less power)..
#18 |
Re: ebay heads?
ok thanks
#19 |
Re: ebay heads?
not trying to steal your thread but what does everyone think about edelbrocks performer RPM heads
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears ![]() 2011 Silverado LTZ |
