Old 12-04-2010, 01:38 PM   #1
montefreak
montefreak's Avatar
230 inline 6 to a 400 sbc...give it to me straight
was just wanting to know exactly what i will need to do to go from a 250 inline to a 400 sbc...i am about to start this project and i know i can rely on you guys on here...please give it to me straight....motor mounts??? i plan on using a 400 turbo tranny..short shaft....will i need to relocate the rear tranny mount???
thanks for all your help!!!!
montefreak is offline   Reply With Quote
Old 12-04-2010, 01:53 PM   #2
NicoSlam
Re: 230 inline 6 to a 400 sbc...give it to me straight
I'm currently in the process of doing the same on my 69SWB but with a 350. engine mounts and their location can remain the same. The wiring will need to be modified if you were not running and HEI on the 250. Also, on my 250, the alternator was on the drivers side and for the 350, it was on the pass. side. Radiator Hoses will need to be changed along with the radiator and fan shroud. I'm not sure on your T400 as I kept the 3speed so I didn't have to modify from the tranny back.
NicoSlam is offline   Reply With Quote
Old 12-04-2010, 02:24 PM   #3
ol_skool_chevy
ol_skool_chevy's Avatar
love to hear how well your 3 speed holds up with that 3 speed....I have one Im thinking of using
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-04-2010, 02:47 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
My son is running a 3 speed muncie behind a slightly modified 454 with a posi without a problem. He is not real easy on it either.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-04-2010, 04:26 PM   #5
raycow
You can keep your present front mounts. If your truck is automatic now you will have to move the crossmember back. The frame rails should already have holes at the TH400 location. If you have a manual tranmission you will have to remove the crossmember that is under the bellhousing and install a new one for the transmission.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-04-2010, 11:29 PM   #6
montefreak
montefreak's Avatar
hey ray...thanks for the info...my truck currently has a four speed manual tranny.....
Old 12-05-2010, 03:10 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
If you're trading out the tranny too you might as well move the engine to the forward holes and use the small block towers. Like stated above you will need to get rid of the crossmember your bell housing is mounted to now and get a auto tranny crossmember. You will have to run the auto linkage and shifter and you can just seal up the hole where your shifter is now or you could even change to a low hump floor. Exhaust will have to be addressed, when I changed mine I just scrapped the stock pipes and had a shop run all new dual exhaust. also you will need to find a different driveshaft or get yours modified. Hope this helps you out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-05-2010, 07:21 PM   #8
montefreak
montefreak's Avatar
hey guys,
i can use all the help i can get...i wasnt sure of the engins mount location..ive heard many different views on were they should be..i guess i should just dive in and then my questions can be asked as i go....thank you all again for your help...i can always rely on this site for help
Old 12-05-2010, 07:55 PM   #9
Jacfourteen
hey guys,
If you were keeping the current tranny I would say just use your stock towers, but since you are swapping to the auto get some small block v8 towers and mounts. There are 3 holes in the top of the frame for the motor towers. Right now with the I6 towers the 2 rear holes are being used, with the small block towers the front 2 will be used. You will use the stock small block motor mounts that these trucks used, they have three holes that bolt to the engine, and one hole that bolts to the tower. I will get you a link to the mounts and towers so you can see what I'm talking about.
Old 12-05-2010, 08:02 PM   #10
Jacfourteen
Here is what the small block v8 stand looks like, it's the one on the right with the small hole in it (if you are wondering the other one with big hole is for v6).
These are the mounts that you need for the small block. Here is a link for them, they cost $7 per side, http://www.autozone.com/autozone/par...3627_195313_0_
