Old 12-07-2010, 10:32 AM   #1
bigunde
Rusty Rockerfeller
Belt not lining up
well i have decided to keep that 86 C-20 and now that im driving it alot, im noticing the serp belt for the alt, fan, and crank it not exactly lining up. the smog pump pulley has been removed so it just those three pullys now but the more i drive it, the more a quarter of the serp belt wants to ride up on the back of the crank pulley. Any ideas? It has the 454
bigunde is offline   Reply With Quote
Old 12-07-2010, 11:37 AM   #2
78 Chevyrado
Re: Belt not lining up
Use shims or spacers to line up the parts/pulleys that are too far rearward. Use a straight edge on the front of the pulleys to line them up and get the angle right.
If you do put any spacers on the pulleys themselves, make sure they are PRECISELY the same (weight and thickness wise) and won't make it wobble or be off balance.
78 Chevyrado is offline   Reply With Quote
Old 12-07-2010, 01:39 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
my 454 was like that too, the balancer was not install'd all the on the crank . it would eat bout 1/4" off the belt .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-07-2010, 03:07 PM   #4
allengator
allengator's Avatar
x2!!!
I would pull the balancer off, clean and lube the crank snout and key area.
Reinstall using a balancer installation tool (NOT a hammer or trying to drive it on with the attachment bolt!)
I bet everything lines up then!
A balancer not installed properly can get loose and break the crankshaft...
Dont ask how I learned this!!
Oh... you can usually rent the installation tool cheap!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-07-2010, 03:19 PM   #5
allengator
allengator's Avatar
OH... one more thing... when you removed the smog pump, did you replace it with the "dummy pully assembly"
If not, the belt tension may not be enough to keep the belt straight!
Allengator
Outta the Blue
Old 12-07-2010, 09:27 PM   #6
bigunde
Rusty Rockerfeller
Thats exactly what this one is doing.
Old 12-10-2010, 04:46 PM   #7
bigunde
Rusty Rockerfeller
Would this installer work? I dont currently own one
http://cgi.ebay.com/ebaymotors/ws/eB...m=400177403807
Old 12-10-2010, 05:00 PM   #8
bigunde
Rusty Rockerfeller
i bought this one
http://cgi.ebay.com/ebaymotors/ws/eB...3011&viewitem=
Old 12-10-2010, 05:05 PM   #9
allengator
allengator's Avatar
Originally Posted by bigunde View Post
That will do the trick!!
Allengator
Outta the Blue
Old 12-11-2010, 07:43 AM   #10
bigunde
Rusty Rockerfeller
Thank ya sir!!!!!
Old 12-11-2010, 09:34 AM   #11
jitteryguy
GoatLube Experss
jitteryguy's Avatar
let us know if thats what it was ! Hope it's nothen more serious .
'85 1/2 ton CCSB
'92 S10 350/350
