Old 11-28-2010, 04:21 PM   #1
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
1972 c10 drop
What is the easiest way to lower a 1972 c10 lwb without c notching the frame. And i want a even stance.
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 11-28-2010, 08:15 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 1972 c10 drop
how much do you have to spend? how low ya wanna go?
John
1999 Toyota Tacoma 4x4
Old 12-02-2010, 01:16 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1972 c10 drop
Easiest and cheapest,... is a spring drop.
The lower you go,... the more is costs.
Spindles up front are the best.
You can use up to a 6" rear drop spring without having to notch the frame.
Keith
Convert to disc brakes.
Old 12-12-2010, 02:17 PM   #4
oldblue72c10
Re: 1972 c10 drop
so if i got springs for the back and drop spindles for the front would that work or would i need springs up front too.
Old 12-12-2010, 02:28 PM   #5
lolife99
lolife99's Avatar
Re: 1972 c10 drop
Spindles will get you 2.5"-3" up front.
Adding springs is up to you.
How low do YOU want to go.
A 4/6 drop is about the max "streetable drop".
Keith
Old 12-12-2010, 02:48 PM   #6
turbo-dog
Re: 1972 c10 drop
do you have rear leafs? not to hack the thread but i want to do the same thing on the same truck...how to go the lowest w/o notching...not opposed to bags, especially if i can use them down the road if/when i do notch.
SO GIVE IT UP FELLAS....what are the best parts/pieces/vendors to use to drop these?
72 C10 Big Block
70 Dodge Challenger, built 440-6 but car in 4k pieces
98 Harley Low Rider Built, wide
98 Chevy Tahoe, million miles
06 Chevy Cobale SS/SC racer( i dont know why)
turbo-dog is offline   Reply With Quote
Old 12-12-2010, 02:51 PM   #7
lolife99
lolife99's Avatar
Re: 1972 c10 drop
ECE
(www.earlyclassic.com)
Keith
