spindles
whats up dudes i just installed a 78 front suspension on my 62. does anyone know who makes these drop spindles? i got them from a forum member and my rotors wont fit. i'm thinkin belltech just because there is a bell stampped on them no other logo, the rotors are from my 62 disc setup and fit the stock 78 rotors just fine the hub is smaller on the drop spindle stock is 1 and 3/8 in drops are 1 and 1/4 in thanks for any help. Tony
Garage wrench
Re: spindles
they look like the western chassis spindles I have, but I can't be 100% sure....
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: spindles
Every pair of Western spindles I have installed has the word "Western" cast prominently into them on the steering arm.
Re: spindles
The C-10 have two different rotors. Early ('82 or so) were 1.25" thickness and later models were 1.00" thickness. I don't know if the was a bearing size change or not. Look up bearings for the early and later models. You may need to find some 1.00" rotors and bearings. Other postings say the cliper will work with either but I couldn't be sure.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: spindles
I posted a reply in your other thread.
All 6-lug aftermarket rotors are the 1-1/4" wide versions. I bet your drop spindles are the Light Duty version. Posted via Mobile Device
#6 | |
Re: spindles
Re: spindles
I have a pair of rotors for ya 1.0 thickness five lug, or?? PM me
| Bookmarks |
