Old 01-10-2011, 12:09 AM   #1
72gmcshorty
72gmcshorty's Avatar
4l60e interchangeable?
What needs to be done to make a 4l60e from a 97 or 99 z28 work with my 2006 5.3 truck motor? My harness is also 2006
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-10-2011, 12:24 AM   #2
78bronzechariot
78bronzechariot's Avatar
Re: 4l60e interchangeable?
I had one out of a '95 caprice laying around and had thought about putting it behind my 2002 vortec. I'm not 100% but if I remember right, but they switched them to a pulse width modulated pump in '96 on rwd cars and '97 on trucks I was told that mine would not interchange. From those points up, I am pretty sure they are electronically the same, so yours should work. if you are using one that has the case and bellhousing for a genI/II (one piece case and bellhousing), I think you will need to get the flexplate spacer for running a th350/400 behind a genIII/IV engine.
78bronzechariot is offline   Reply With Quote
Old 01-10-2011, 12:24 AM   #3
63chevyll
gets board easy.......
63chevyll's Avatar
should bolt right up, maybe just change trans mount...and the connector should work also
63chevyll is offline   Reply With Quote
