Senior Moment
![]() Join Date: Mar 2002
Trans Died
My trans let go tonight. LOTS of metal in the pan.
Now the ? is do I rebuild the T350 to handle the Big Block when it goes in OR go T400. Thoughts and Opinions Please
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Member since 2000
have you thought about a 700r4? I hear that th350 can be stronger then th400 build right too. Stock the th350 is weaker but if your going to rebuild so why not put stronger parts in it.
Senior Moment
Good point Alexis and thanks for the input
Anybody else have thoughts on this
14.1 @ 96MPH
I would personally recommend a 2004R or a 700R4 in this case.
Project1970 - LS1 Swap Complete! ![]() |
newly minted old timer
put the th350 back in.. those 700r4s are more trouble than they are worth. unless you have lots of money do have it done right, even then you chancing it. i hate those dam things!
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
Fabricate till you "puke"
If you plan on running a BB, I would go 400 turbo & bolt a Gear vendors on the back. Altho not cheap, the Gear vendors is said to be a very durable O/D unit. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
rebuild the 350 with stronger parts, that is what I did with mine & it has held up to all the punishment my BB can give it.
69 swb GMC, 402 BB, 3:73 posi, 3" exhaust, forever a work in progress |
Senior Moment
Thanks for all the input. The T350 is being beefed up. Should have it back Wed $650 includeing TC.
