Old 01-16-2011, 07:01 PM   #26
halfcockedcustoms
halfcockedcustoms's Avatar
Re: Performance Online POL ::anyone used this kit?
sweet
halfcockedcustoms is offline   Reply With Quote
Old 01-16-2011, 07:40 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Perfect stance!
Keith
Convert to disc brakes.
Old 01-16-2011, 08:16 PM   #28
tommyd241
tommyd241's Avatar
Came out really nice!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 01-16-2011, 11:02 PM   #29
protrash64
Resistance is Futile
protrash64's Avatar
Nice work thunder; truck looks killer!!!!!!!!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-29-2011, 09:20 AM   #30
thunder71
thunder71's Avatar
well took it for alignment & all is good the disc brakes stop 100 times better then before & would recommend this kit to anyone...thumbs up to POL
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 01-29-2011, 11:40 AM   #31
halfcockedcustoms
You work alot faster then me,,,I just got my calipers put on last night
Old 01-29-2011, 11:25 PM   #32
thunder71
thunder71's Avatar
WOW i guess so me & my son took about 3 hours for each side for the install....it sure gets allot of attention whenever she goes...i love the stance
Old 01-29-2011, 11:31 PM   #33
lolife99
lolife99's Avatar
x2
I've always had good luck with them.
Again,... your truck looks Sweet!
Keith
Old 03-03-2011, 12:28 AM   #34
Orangetonicclicc
Orangetonicclicc's Avatar
Sounds like you had a great experience with POL. In the process of trying to find someone to purchase a full disc brake conversion kit from. For my 67 SWB any advice?
Orangetonicclicc is offline   Reply With Quote
Old 03-03-2011, 07:14 PM   #35
thunder71
thunder71's Avatar
i would try POL, easy fast install with everything needed
Old 03-04-2011, 12:33 AM   #36
Orangetonicclicc
Can I get a discount number off this forum?
Old 03-17-2011, 07:40 PM   #37
thunder71
thunder71's Avatar
OK, i got a code to use from 3-17-11 through 3-20-11...it is SP1811 good for 10% off...here is the add>>>
Hurry catch this St. Patrick's Day 10 percent OFF SALE before its gone!
Only four days March 17th - March 20th.
Enter Coupon Code: SP1811 at checkout.
Or give us a call with this coupon code number and Receive 10% off your entire order.
Old 03-17-2011, 08:05 PM   #38
Orangetonicclicc
Yes. I just bought the kit. I've installed the rear not the front. The major question you need to ask. is wiil your rims fit on that disc brake application.
Old 03-17-2011, 08:19 PM   #39
thunder71
thunder71's Avatar
Thumbs up Re: Performance Online POL ::anyone used this kit?
i am running 15" rims & had to grind just a touch off of the calipers...lets see some pix when done
Old 03-18-2011, 02:00 PM   #40
stealth_weapons
my kit should be in on Monday. i only got the front disc, drop spindles, power booster, master cylinder, sway bar, tubular control arms upper and lower, tie rod ends, adjusting sleeves, and complete rear drum rebuild kit. i cant wait. i have CPP 3/4 drop springs on it(on the truck when i bought it).
stealth_weapons is offline   Reply With Quote
Old 03-18-2011, 02:14 PM   #41
Clyde65
Clyde65's Avatar
^^^ That's all you got!?
Jk, that is a bunch for sure, good luck with the install!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
