Old 01-24-2011, 11:39 AM   #1
REDNOSE65
REDNOSE65's Avatar
Need help from the 60-66 Experts...
I bought my 65 Chevy Step Side in about 1996. The previous owner didn't do anything to it and the person he bought the truck from is long and gone. He did all kinds of stuff to the truck, but did more harm than good meaning more work to make it right. Any how, to start with it has leaf springs in the rear. I don't think that's original, is it? The cab mounts align perfect. The rear is a different story. The bed doesn't align so much. I tried installing the rear bumper, but the brackets don't align at all. Can anyone tell me what years used leaf springs? 60-61??? Any info will be greatly appreciated. Here are some pics to I hope explian what I'm talking about.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 01-24-2011, 12:02 PM   #2
REDNOSE65
REDNOSE65's Avatar
Re: Need help from the 60-66 Experts...
a few more pics...
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 12:10 PM   #3
Clyde65
Clyde65's Avatar
I am not an expert but, I believe that the leaf spring 1/2 ton trucks were all GMC. It appears that the frame has been changed to something else, were the 67-72 rear frames wider than 60-66? IDK that but could it also be that the rear bed frame mount there is the wrong one? Is there someone you can get some measurements from?
Does the front of the bed line up?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-24-2011, 12:20 PM   #4
REDNOSE65
REDNOSE65's Avatar
The front of the bed aligns somewhat. We had to raise it a lil bit to put the step brackets. The bumper brackts, which I got brand new, don't align att all. I'm afraid my truck was butchered before I got it.
I'm just trying to make chicken salad outta chicken $*!t*.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 12:22 PM   #5
Clyde65
Clyde65's Avatar
can you see if it has been butchered after the rear cab mount? IDK why someone would but I have seen it cut after and "spliced" together. Measure your frame in the rear and see what we get there.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2011, 12:23 PM   #6
Clyde65
Clyde65's Avatar
Does the rear of the frame kick up a bunch after the cab?
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2011, 12:33 PM   #7
padresag
leaf springs were optional on Chevrolet trucks. looking closely at the little that can be seen of the spring hangers, they appear to be riveted in place which usually denotes factory
ron
padresag is offline   Reply With Quote
Old 01-24-2011, 12:35 PM   #8
REDNOSE65
REDNOSE65's Avatar
ron
I'm about to go take measurements. Take more pics while I'm there.
Thanks for the input guys.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 12:54 PM   #9
Clyde65
Clyde65's Avatar
Im still wondering if the rear and maybe front bed supports are maybe different too.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2011, 01:02 PM   #10
64shortc10
64shortc10's Avatar
I'm no expert, but I did purchase a 62 chevy truck to swap the bed to my 64 and the rear bed mounts are the same way as you have pictured and mine is a fleetside with coils.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 01-24-2011, 01:08 PM   #11
Clyde65
Clyde65's Avatar
LMC does show there is a different part number for 60-62 and 63-66 rear bed mounts so 64 short might be correct.
Here is the page
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=23
I went and looked at my truck (65) pics and it looks like mine are the wider rear mount.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2011, 01:25 PM   #12
oem4me
The frame rails are different widths for early and late. I bought a nice rear step bumper from a 66 to install on my 62, but I had to relocate the brackets first. It appears something has been swapped on your truck.
Old 01-24-2011, 01:30 PM   #13
TopFuel1966
TopFuel1966's Avatar
I had the same bed alignment problem with my '66. That's when I discovered that the bed was from a '62 or earlier. Simple fix.......just move the mount tabs.
TopFuel1966 is offline   Reply With Quote
Old 01-24-2011, 06:24 PM   #14
REDNOSE65
REDNOSE65's Avatar
That sounds easy enough, but what about the rear bumper brackets? I wonder if I should try for an earlier model...60 or 61?
Here is the page
Outside to outside to my frame is 34".
Tony from Norcal
Thanks Tony.
Not really and I didn't see where the frame might be cut and rewelded. Maybe it's a GMC frame??? I heard GMC used the leaf springs in those years.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 06:26 PM   #15
REDNOSE65
REDNOSE65's Avatar
...and thanks again for all you guys input. My goal is to find the correct bumper brackets. I want to lower it as well.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 06:41 PM   #16
Clyde65
Clyde65's Avatar
Like was said above Red, maybe you have a 60-62 frame. and there were some Chevy's with Leaves too. I hope someone here can measure their 60-62 for you so you can be sure.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2011, 06:49 PM   #17
REDNOSE65
REDNOSE65's Avatar
Funny, I steeped away from the computer Clyde, and that's exactly what I was thinking. I hope someone can let me know if it's a 60-62. I just called on the rear bumper brackets and they said they'd switch them out for me. The bumper is the same. Thanks for all your help Clyde!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 07:00 PM   #18
padresag
the 60-62 frame is further apart than the 63-. so you have a 62 box on a 64 frame, doesn't line up.
you need a 64 bumper and brkts
ron
Old 01-24-2011, 07:09 PM   #19
REDNOSE65
REDNOSE65's Avatar
ron
I bought 63-66 brakets that didn't work.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 07:15 PM   #20
padresag
what bumper are you trying to use?60-62 or 63-66. you can only use the 63-66 bumper on a 64
ron
Old 01-24-2011, 07:19 PM   #21
gimmy 64
my 64 gmc with leafs measures 34 in. outside frame to outside frame. sounds like your bed is from earlly model
gimmy 64 is offline   Reply With Quote
Old 01-24-2011, 07:20 PM   #22
REDNOSE65
REDNOSE65's Avatar
ron
My truck is a 65 Step Side the bumper I bought is 60-66.
The Classic Industries Catalog shows the same bumper was used on step sides 60-66.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 07:21 PM   #23
REDNOSE65
REDNOSE65's Avatar
Is it fleet or step? My frame measures the same.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 01-24-2011, 07:23 PM   #24
gimmy 64
mine is short fleet
Old 01-24-2011, 07:35 PM   #25
maynardtruckin
maynardtruckin's Avatar
the frame looks like a 73-87 frame
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
