Closed Thread
Old 01-30-2011, 11:11 PM   #1526
Rob H.
Rob H.'s Avatar
Re: What did you do to your truck today!
Started the '72 up after it had sat for 6 months without moving. Moved it under it's own power to a differant location in the yard. Still don't have the brake lines done or carrier bearing changed, not having a garage and all the snow and rain we've had has really slowed down my progress!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 01-30-2011, 11:43 PM   #1527
Heavy Evy
born to lose
Heavy Evy's Avatar
Checked all my vitals and changed out the header gaskets at work today. One of these days im just going to get fed up and go back to rams horns. im tired of blowing header gaskets!!!
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline
Old 01-31-2011, 12:21 AM   #1528
cokeb
Originally Posted by Jeffs70 View Post
created a mold for my center console to begin fiberglassing the shape. and got closer to finishing my radiator/core support cover
are you building a console for a bench or bucket seats? my son and I are building one for a bench and would be interested in seeing what others are doing.
thanks,
Craig
cokeb is offline
Old 01-31-2011, 12:59 AM   #1529
Jeffs70
Jeffs70's Avatar
thanks,
Craig
Hey Craig,
I am creating one for bucket seats with a B&M Shifter.
Yeah would be nice to see your art work also.
Jeff
Jeffs70 is offline
Old 01-31-2011, 03:19 AM   #1530
project 67 sub
project 67 sub's Avatar
bought some body filler (the better cheap crap from autozone) so i can start doing the body work on my replacement fender, bought a few more tools to and stuff to use to work on it with, bought some electrical stuff, bought my push starter button, drilled the mounting hole and installed it, just need to wire it up. i decided to go with the blue cover instead of the red or clear that it came with, i just wish it lit up, but oh well what do you expect for $30 . i also started doing some more wiring repair under the dash, should have done that when it was out because it would have been alot less hassle, oh well live and learn haha. i also added the headlight and wiper switch connectors back on (sorry no pics of that) as i decided to run the stock switches again.
project 67 sub is offline
Old 01-31-2011, 10:57 AM   #1531
bigdogboxers
bigdogboxers's Avatar
Picked up the 1962 gmc long bed well at least what was left of it....
bigdogboxers is offline
Old 01-31-2011, 01:45 PM   #1532
RenoKeene
Florida Edition
RenoKeene's Avatar
While cleaning out the shop for my suspension swap I found this.....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline
Old 01-31-2011, 02:09 PM   #1533
project 67 sub
sweet, i say tear it apart and put a 67-72 truck body on it
Old 01-31-2011, 02:16 PM   #1534
LeatherMan69
Looked at it and shook my head in disapointment that its not farther along.
LeatherMan69 is offline
Old 01-31-2011, 02:17 PM   #1535
RenoKeene
Florida Edition
RenoKeene's Avatar
Exactly what I was thinking. 102" wheelbase with a 9:1 358 Bush Cup motor in it running thru a jerico and 180 deg headers.
Old 01-31-2011, 05:17 PM   #1536
DT1
DT1's Avatar
Found a big bubble in my paint the other day and when I pushed on it, it cracked. So much for a $4,000. paint job!
This weekend I decided to fix it since I had some of the paint left over.
Before...
After...
DT1 is offline
Old 01-31-2011, 05:23 PM   #1537
wwotr
wwotr's Avatar
Before...
After...
NOOoooooooooooooooooooooo..........................
(THAT SUCKS).
How old was the Paint?
Any recourse with the Person/Shop thatr did it!!??
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 01-31-2011, 10:01 PM   #1538
Sonicman
Sonicman's Avatar
Got my blazer tank to put under the bed and get that in cab tank out!!!
Sonicman is offline
Old 01-31-2011, 10:57 PM   #1539
glider_6969
Ever have trouble keeping that camper hooked up to that , sorry couldn't resist
glider_6969 is offline
Old 02-01-2011, 03:05 AM   #1540
mcmlxix
Collector of Projects
mcmlxix's Avatar
Got some more parts for the shackle flip and 14BFF upgrade.... DIY4X and Ruff Stuff....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 02-01-2011, 05:32 AM   #1541
project 67 sub
got some more fittings and line for the rear bags, relocated the ignition switch to the inside of my center console, extended the wiring for the ignition and wired up the starter button. all wiring is done under dash for now except for the gauges which i can do from the front of the dash where the cluster goes.
Old 02-01-2011, 05:57 PM   #1542
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Installed the faux-radio (gutted a non-working stocker to fill the dash hole). Checked the door install I did yesterday. It'll need a little more "lining up". Jacked up the back two corners again to check the fit of the roll pan. Warmed up the welder for some roll pan bending/installing when it's a little warmer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-01-2011, 07:17 PM   #1543
justagoodolboy
Under Construction
justagoodolboy's Avatar
Did some wire tracing, found a problem and then got it started! Man I'm still pumped! it's about a year and 2 months since I last heard it run. It sounds a lot better to my ears now then it did then. Dunno why, guess it's all the hard sometimes frustrating work I put into it. I drove it a few feet inside the shop just to say I did. Now to find a tailgate and I'm ready for paint!
72 chevy 4x4-my project
67-72chevytrucks.com/vboard/showthread.php?t=368210
94 Nissan 4x4-Daily Driver and off road beater
03 Saab 9-3 -tripper
90 Polaris Trail Boss- 2 Stroker
justagoodolboy is offline
Old 02-01-2011, 07:55 PM   #1544
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Lowered the rear a couple more inches and installed my adjustable panhard bar kit. Finally had some NW weather that wasn't crap so I took it for a spin and some pictures. Yeah!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline
Old 02-02-2011, 09:26 AM   #1545
ffk
ffk's Avatar
thinking about getting the 26 inches of snow off the truck..before the 40 - 60 mph winds ....the whole area is shut down..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline
Old 02-02-2011, 07:52 PM   #1546
makman1297
makman1297's Avatar
Installed my steering gearbox and primered the cab bottom.
makman1297 is offline
Old 02-02-2011, 10:25 PM   #1547
BadaSs_Cal
BadaSs_Cal's Avatar
Looked at her.. then before I got into the Honda I ran my hand accross her hood... Bringing her old head to the machine shop to have cleaned and fit to her new motor.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline
Old 02-02-2011, 11:31 PM   #1548
wwotr
wwotr's Avatar
Got my new Chrome Dome Light Base, Clear Diffusing Lens and Replacement LED Bulb.
Also picked up some Chrome Sun Visor Brackets and a set of Interior Door Handles, to take to the Upholsterer tomorrow. He'll wrap them in Leather and match them up to the rest of the Interior he's re-upholstering.
Cab goes into Primmer tomorrow and paint by next week.
Then we button it back up!
2 years in the making....I can hardly wait!
Hello members...
RIP...."RATIKLE"
wwotr is offline
Old 02-02-2011, 11:47 PM   #1549
magwakeenercew2jh
Originally Posted by wwotr View Post
....snip....
Congrats, wwotr.
Installed the "new" tilt column. Got sick spraying some primer under the bed and came home.
Thanks to ECE, and especially to my wife, for the tilt. Fit like a glove.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-02-2011, 11:59 PM   #1550
Hart_Rod
Hart_Rod's Avatar
Aluminum gauge panel and glove box door, .
Hart_Rod is offline
Closed Thread
