Old 01-30-2011, 11:33 PM   #1
3r!c84
Badass
3r!c84's Avatar
temp gauge not working..
temp gauge was working fine before i messed with it lol you know how thats go's
but did a tach/fuel gauge swap love it! works great all that works. everything is working fine but my temp gauge. what did i mess up on it. didnt touch anything on that side.. but what do i need to check to fix it? the wire going to the temp sender on the head is fine. wire is not burned up or cut.
give me a little help guys thanks
truck is off btw oil psi is not that low running...
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-31-2011, 07:28 AM   #2
2badgn
Re: temp gauge not working..
Nice gauges. What year r they from? It would look perfect in my dad's 84 GMC 3500!
2badgn is offline   Reply With Quote
Old 01-31-2011, 08:05 AM   #3
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Did you double check your connections? maybe your printed circuit has a bad spot??
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 01-31-2011, 10:44 AM   #4
3r!c84
Badass
3r!c84's Avatar
camero lots of moding. not a drop in fit.
that all looked good.
anyone know what kind of voltage or resistance ut should have in the prongs behind the gauge ?
-00 Saturn 5spd
1/4:13:90
Old 01-31-2011, 07:51 PM   #5
Silence86
Silence86's Avatar
mine just went out to... crazy how that works..
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 01-31-2011, 08:02 PM   #6
78cheyenne292
mine only works when the engine is warm ever since my printed circuit caught fire!
78cheyenne292 is offline   Reply With Quote
Old 01-31-2011, 08:21 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Hope it's just the gauge itself, that would be easy enough to fix.
Love the clock... I have one in a box somewhere that I need to install.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-31-2011, 08:29 PM   #8
3r!c84
Badass
3r!c84's Avatar
its unpluged it do work but it runs down the battery when it sits for a week. its set at 5o clock tho (: its 5o clock somewhere right?
-00 Saturn 5spd
1/4:13:90
Old 02-01-2011, 12:40 AM   #9
Yupiamlo
Yupiamlo's Avatar
Hey mine stopped working too, I think Im missing the wire that goes from the gauge to the sensor, is it just one wire? what do I need to replace it?
And at some point they must have had a tach in these trucks cause I saw one on ebay the other day it sold for like $80, and I think it said it was from a 76?
Yupiamlo is offline   Reply With Quote
Old 02-01-2011, 12:53 AM   #10
3r!c84
Badass
3r!c84's Avatar
They did it's a rare opation tho. Or on bigger c30 trucks.
-00 Saturn 5spd
1/4:13:90
Old 02-03-2011, 12:33 PM   #11
Silence86
Silence86's Avatar
did you ever figure this out?
Old 02-03-2011, 12:50 PM   #12
3r!c84
Badass
3r!c84's Avatar
nope. dont feel like pulling the dash out and get my voltmeter out lol ill do it with in a week
-00 Saturn 5spd
1/4:13:90
Old 02-03-2011, 02:26 PM   #13
kikkegek
kikkegek's Avatar
If I am correct the sender is has an ohm resistance at a certain temperature. But I also dont know if the sender is PTC or NTC.
kikkegek is offline   Reply With Quote
Old 02-03-2011, 02:40 PM   #14
Silence86
Silence86's Avatar
is it possible the wire to the temp sender got burned, i looked under hood to find it on the header
Old 02-03-2011, 04:39 PM   #15
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
I believe if you ground the wire out on the frame, the gauge should peg. If that works, I would believe its the sensor thats gone bad
75ChevyGuy is offline   Reply With Quote
Old 02-03-2011, 05:33 PM   #16
3r!c84
Badass
3r!c84's Avatar
wire is not burned up on the header. ill double check tho and try to ground it out.
-00 Saturn 5spd
1/4:13:90
Old 02-04-2011, 02:04 AM   #17
355bullet
355bullet's Avatar
Here ya go man, this is how i fixed mine. I use to buy these at the local car quest. The company that use to sell them went out of busniess..i guess..i cant locate them with the old packaging.These really work, i have them in both my trucks
So i had one of the technicians at work check the resistor to see what kind it is so i can make more for myself in the future. Cuz this is my last one.
I was told you can buy them at a radio shack, then u can crimp the connectors.
This resistor works for oil, temp, and amp
355bullet is offline   Reply With Quote
Old 02-04-2011, 02:10 AM   #18
3r!c84
Badass
3r!c84's Avatar
i can get gauges at the bone yard like nothing. if its a gauge thats a easy fix !
-00 Saturn 5spd
1/4:13:90
Old 02-19-2011, 11:15 AM   #19
Yupiamlo
Yupiamlo's Avatar
Sorry still stuck on the tach thing, why can't you get a repop Tach anywhere, LMC and Classic parts don't sell them, but they sell every other one
Old 02-19-2011, 01:31 PM   #20
3r!c84
Badass
3r!c84's Avatar
Repop of the camaro tach or the stock truck tach?
-00 Saturn 5spd
1/4:13:90
Old 02-20-2011, 12:23 PM   #21
Yupiamlo
Yupiamlo's Avatar
Stock truck tach
