Old 01-02-2010, 06:18 PM   #126
mcbassin
Still Learning
mcbassin's Avatar
Re: project BIG RED (gen3 on air)
Great progress! You will driving this truck soon at this pace
Old 01-02-2010, 06:45 PM   #127
68 short step
well, the cab still has to come off again... but ill get all the sheetmetal replaced on it first...itll get there tho
68 short step is offline   Reply With Quote
Old 01-02-2010, 08:13 PM   #128
killer71
killer71's Avatar
I'm diggin the new tires/wheels. They go great with those mirrors, in fact i think you oughta throw a set of cab lights on it and roll it!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 01-02-2010, 08:20 PM   #129
68 short step
thank you, i was going for that retro look... and those are dummy mirrors, with a simple 90* rotation they become wings and i can fly...
Old 01-02-2010, 08:34 PM   #130
killer71
killer71's Avatar
ya know what they say...gotta have the picts to prove it!
R.I.P.
Killer 71
10/26/07
Old 01-05-2010, 12:41 AM   #131
68 short step
got the cab all bolted down, also the piece on the edge of the cab (that he fender and wiper cowl bolt to) was all rusted out, so it was cut out, and another piece fabbed up...i welded it in and smoothed the welds down...also got the front fender bolted on, i wanna try and re-use the stock inner fenders and hood hinges...
and brrrrrrrrrrrrrrrrrr, it was cold in the shop today.
Old 01-05-2010, 12:42 AM   #132
68 short step
Old 01-05-2010, 12:47 AM   #133
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Don! Your cab and firewall look great! And man does that LS look sweet perched in there. Hey, what motor mounts/stands did you use and did you make your own adapters? Yep, it was too cold for me to even go out in the shop tonight.
Old 01-05-2010, 12:52 AM   #134
68 short step
tubular engine mounts from performanceonline.com, and the adaptor plates were from thecarshop.com (i think thats the name)
Old 01-05-2010, 09:59 PM   #135
speeddemon619
I realllllly love how that ls looks in there, better yet will be the fuel economy and modern reliable engine.
speeddemon619 is offline   Reply With Quote
Old 02-03-2010, 11:19 PM   #136
Chevy-Art
Chevy-Art's Avatar
Are the headers you are using on this one, the same as you are using on the hulk? 98-02 Camaro. Where did you buy them from?
1990 Chevrolet RCSB●LS1/4L60E
Scrimpin Ain't Easy
I'm not a mechanic, I'm not a tuner. I'm just an enthusiast.​
Chevy-Art is offline   Reply With Quote
Old 02-04-2010, 08:14 PM   #137
68 short step
yelp, same headers... i got them from texas speed
Old 02-04-2010, 11:26 PM   #138
Vega_67C10
Vega_67C10's Avatar
Congo-rats Short Step! Nice build and nice work, I like it.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 02-05-2010, 12:55 AM   #139
nuke1
nuke1's Avatar
nice work Don, i like the way it sits, very nice. Job well done so far.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-07-2010, 08:36 AM   #140
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 68 short step View Post
the power steering fittings PN are this from summit
AER-FBM2965 6AN TO 11/16 INVERTED FLARE
AER-FBM2964 -6 AN Male to 5/8-18 in. Inverted Flare
EAR-991955ERL -6 TO 16MM X1.5 POWER STEERING
Don - do these adapters allow you to use the LS style factory lines?
Hart_Rod is offline   Reply With Quote
Old 02-07-2010, 09:50 AM   #141
68 short step
no, thats the PNs to use the braided -6 AN line....
Old 02-06-2011, 12:37 PM   #142
68 short step
man this thread is wayyyyyyy over due...here we go with a BIG update...
the driver side sheetmetal was crappy, and repared useing fiberglass, bondo, and chicken wire...so everything was replaced... cab corner had to be extended 2" due to the fact that someone replaced the old one with the entire replacement panel, giving me no room to work with good metal..also the front cab support was replaced, the inner rocker pnl, toe board, and outer rocker pnl...then i found cracks in the door, where the hinge bolts to, tried to weld them up, but blew right through...so i started poking around and that metal was supper then, lucky the door didnt fall off when opening it ... so the driver door was replaced with a good used one, i picked up from kennys trucks..
Old 02-06-2011, 12:49 PM   #143
68 short step
and then the same on the pass side...which looked good until i tore into it..
Old 02-06-2011, 12:52 PM   #144
Hart_Rod
Hart_Rod's Avatar
Nice metal work! You gott love those "shade-tree" body guys......
Old 02-06-2011, 01:03 PM   #145
68 short step
the front fenders had some rust/repairs on the bottom front.. so instead of fooling with it i desided to just replace it all.. here are a few pics of it all bolted together
Old 02-06-2011, 01:07 PM   #146
robnolimit
robnolimit's Avatar
That makes me feel lazy for buying a nice cab, and mine wasn't neer that bad. Hope your not freezin'
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-06-2011, 02:32 PM   #147
68 short step
ya, thats the way to go for sure....not freezeing at all, got the heaters keeping the shop a nice 68*
Old 02-06-2011, 02:57 PM   #148
67chevy1series
67chevy1series's Avatar
i love the rims......
67chevy1series is offline   Reply With Quote
Old 02-06-2011, 04:39 PM   #149
jasonhall
jasonhall's Avatar
Looks great! Where did you get your fenders and are you happy with how they fit?
jasonhall is offline   Reply With Quote
Old 02-06-2011, 11:33 PM   #150
jwalk
What was I thinking?
jwalk's Avatar
You might not remember me, but we met once before in okc.... but any ways this truck is looking great! That rust repair/metal work looks really good!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
