Old 02-07-2011, 12:58 AM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Trucks got no kick down?
My truck has always had this issue and i just never thoguht about it (as it drives an shifts fine etc.)
But from a dead stop if you jump on it it has no get up and go and if your driving along and just step on it it will not kick down into passing gear.
Trucks a 84 C35 with a 350 a T400 and a D70 rear end.
Any help to get some life back in this boy would be great!
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 02-07-2011, 01:08 AM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: Trucks got no kick down?
i had this problem besause my downshift cable on my th350 was jammed inside the transmission. instead of opening it up to fix i just swapped in a TH700r4.
another reason i switched transmissions is because i blew up the th350 in the driveway atttemting a neutral drop hahaha
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 02-07-2011, 01:16 AM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Someone told me the T400 was vaccume kick down? because there is no kick down cable? idk never played with these trans b4
Old 02-07-2011, 01:58 AM   #4
bigd65
bigd65's Avatar
Its elctronic. Look on your gas pedal and you cans see the switch, follow the wires make sur they are hooked up. Then under the hood there should be an orange wire with a fusable link in the wire, That fusable link could be blown. Then check down to the transmission ans make sure its hooked up.
Im in the process of straightening out some wires and I already found that.
There is ALOT of knowledge on this site, someone else will chime in as well
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-07-2011, 02:23 AM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
LOL that would make sence. as 90% of the wireing is hacked to crap will start looking into it. thanks.
Old 02-07-2011, 11:17 AM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
No switch on the pedel and the fuseable link seems to be all hacked. FML i need to find a god donar truck as trying to find wireing in a junk yard is useless (ppl just cut stuff.)
Old 02-07-2011, 12:22 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Was tlaking to a buddy. think i got it figured out Trucks got no switch or wire to the trans on the river side. off to the junk yard i go i guess.
Old 02-08-2011, 09:35 AM   #8
bigd65
bigd65's Avatar
You can just buy another fusable link, I think its a 25, thats what was printed on mine. I just bought and inlive fuse holder and put a 25 fuse in it. I have not hooked it up yet. I have my interior striped out. Found the rust I thought was not there. Just on the floor panels by the kick panels. At any rate, gonna fix them before I go much farther.
