Old 02-13-2011, 08:59 PM   #1
81c10
81c10's Avatar
Alright. Tires are done. Next project!! HEADERS!
Who has some suggestions for headers? I am going to wrap them before I put them on and they will run true duals into Flowmaster Super 44's with no cat. Any opinions? What brand sounds good...Holds up well...makes performance improvements...Pics welcome.
lml
81c10 is offline   Reply With Quote
Old 02-13-2011, 09:08 PM   #2
mongoose
mongoose's Avatar
Re: Alright. Tires are done. Next project!! HEADERS!
any specific reason why you want to run header wrap?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 02-13-2011, 09:19 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Unless you're a 2000hp car. I wouldn't run header wrap. Most of the lower end headers aren't made to handle the wrap and they crack and break.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-13-2011, 09:23 PM   #4
81c10
81c10's Avatar
Other than the better heat excavation it looks metal. That's about it really. Its all about keepin the temp down under the hood. Helps for intake as well. (Air temp) I've tried coating my headers before and did not get good results. So maybe some high temp paint as well as wrap will work. Ceramic headers would be nice but those are out of my budget at the moment...
Old 02-13-2011, 09:25 PM   #5
81c10
81c10's Avatar
Really. Any suggestions for header set ups then? I havent made up my mind yet. Just putting together ideas.
Old 02-13-2011, 11:47 PM   #6
Toxic Redline
Toxic Redline's Avatar
i have Hooker Comps and i love them great sound and performance one thing i could tell you is no matter what kind of headers you get at one point you will say somthing like " these F*&^%*# P.O.S." the bolts always seem to be a pain to get in and the block to manifold gaskets will blow out more then with stock manifolds.. I have only had to change my gaskets once and i've had it two years, but my buddy has some Johny Tiwanies and he seems to go through gaskets like every three months.. Im a fan of the aluminim gaskets that are like doubled up, they are made to be reused.
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-13-2011, 11:51 PM   #7
Toxic Redline
this isnt the best picture but those are Hooker Competition, they have the welded on badge that says so.
68 c20 dump bed
Old 02-13-2011, 11:57 PM   #8
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
I had some Hedmans on a '79 K5 that I was happy with and they were very durable. They were on the truck before I bought it and were there when I sold it. Fit great and never rusted.
I had some Hooker Comps on a '65 Impala which I only drove once a year or so, but I definitely had to bang some tubes to get them to fit right. Also, changing plug access sucked.
If this truck is a daily driver, stay away from the header wrap. They trap in moisture and will rust your headers prematurely.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 02-14-2011, 12:02 AM   #9
bigblock73
yeller
bigblock73's Avatar
I have run Hookers on most of my trucks, my 73 now has Sanderson headers...I like them a lot more than the Hookers.
bigblock73 is offline   Reply With Quote
Old 02-14-2011, 01:51 AM   #10
3r!c84
Badass
3r!c84's Avatar
hooker. jet-hot coated
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-14-2011, 03:08 AM   #11
givengold
Sanderson, and wrapping them traps moisture from condensation when heating up and cooling down. The headers rust out much more quickly. You are just trapping the heat in them. Leave them unwrapped and let the heat and moisture dissipate.
givengold is offline   Reply With Quote
Old 02-14-2011, 03:30 AM   #12
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Dougs ceramics... running duals with super44flowmasters no cats.
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 02-14-2011, 07:29 AM   #13
81c10
81c10's Avatar
That's good to know because right now it is. Perhaps ill just go with a temp coating...
Old 02-14-2011, 08:25 AM   #14
BigBlocksRule
^ Winner, winner, chicken dinner!
Don't use the wrap unless you're forced to. It works great for the turbo guys, they need all the help they can get and ceramic coating generally isn't enough.
Save your nickels and dimes until you can afford good ceramics.
BigBlocksRule is offline   Reply With Quote
Old 02-14-2011, 09:50 AM   #15
81c10
81c10's Avatar
Agreed.
