Active Member
![]() Join Date: Jan 2004
Re: i need help to remove the dash trim
You have to completely remove the dash pad. Once it's off you can access the back side of it where you very carefully remove the speed nuts holding the plastic dash trim. It's not that difficult but the biggest challenge is removing those speed nuts from the backside without breaking the fragile plastic studs they're attached to. Pretty straightforward once you get there. Good luck.
Lane 1979 Chevy SWB- (Second owner- Father in Law was first) 1979 Chevy Silverado SWB-Red/Red |
| Bookmarks |
