i might have found a 6.0
i might be picking up a 2001 gmc sierra 4x4 that has the front end smashed,if i get it for a good price is it worth it?or is there a better year to get?if i get it what do i realy need to keep if i use it fuel injected?i might go carburated,but ill have time to figure that out
87 short bed.4",6" drop sold 90chev z71 6" lift. with 35"sold 07 4x4 colorado on 31" 1971 chev blazer |
Re: i might have found a 6.0
Leave the intake and fuel injection on it just like it is, that is a good year to get as there is no fly by wire, just need stand alone electronics (several suppliers) and you are good to go. Use the trans. to!, might as well use the 14bolt and disk brakes while you are at it, can be switched to 6 lug if you like.
Do a search on here and all over the internet, this is all the rave right now, TONS of talk out there! Last edited by Shawn5488; 02-21-2011 at 08:00 PM. |
its going in my 2wd,so either i get an other trans or use my 700r4
![]() Join Date: Aug 2004
Id use your 700, hopefully it is a little built to handle the HP the 6.0 will muster. Right out of the box with a performance tune and headers it should run 400HP easily. If you do a cam and such, &450-500 is not unrealistic at all.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Why cant you use the 4L80E in your truck?
just my .02, I would throw the 6.0 in there with the 700, take it easy for a while and when your ready to upgrade the cam and such, go ahead and upgrade the trans too.
i went and looked at the truck yesterday,man did he hit hard,im going to make a redicules offer on it.and if he takes it il se if theres anything worth salvaging.its hard to tell,but the frame is all bent,and he took the wheels of so its sitting on the ground
| Bookmarks |
