![]() Join Date: Jul 2010
Re: No Limit '72 C-10
Yes, we made the lower motor mounts. I'll put up a layout of the rear Z. This week we installed a Richmond Gear "LockRight" posi. The cost $398. + 23.88 for oil and a new gasket. The install was easy, and we're not gear guys here. We opened it up and followed the directions. No special tools needed. It took about 2 hrs. We put it on the scales. Now for comparison, It's pretty stock, no A/C, iron 4 speed, 350. Total weight is 3796. it lays out like this - LF = 1188, RF = 1106, LR = 755, RR = 747. Front weight is 60.4% It's easy to see that we should move EVERYTHING back, and to the right. This is without the driver, who will only make things worse. Our new (used) Ls, is lighter and farther back, and the headers will help too. The L460 is lighter than the 4 speed, and we have already moved the tank and battery back. THEN< last night we went back to the track. The posi makes it a whole new deal. It used to be a drift out of every corner, now it grips and goes. A bit too much if your used to the drift (can induce a spin, once or twice
) But with only the posi added our times dropped to 54.45 sec. Thats about 1 1/2 sec off our previos best 56.10. And the fun continues......
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 03-02-2011 at 01:15 PM. |
| Bookmarks |
| Tags |
| 1972 chevy, c-10, no limit engineering |
