Old 10-15-2011, 08:27 PM   #11
Ackattack
Ackattack's Avatar
Re: No Limit '72 C-10
Originally Posted by robnolimit View Post
we did flip the trailing arm mounts, to raise the anti-squat. The coating is called 'Raptor' liner, and its like a spray on bed liner. It's tough stuff, and easy to use. The cab was pressure washed, and sealed. We had to make raise the trans tunnel, so that was done and sealed up too.
Wow, great build. I love the inovation and developing parts to improve handling.
I really like how you re-located the lower ball joint. I'll have to look into this.
My question is, can you raise the anti-squat too much? Because the anti-squat lines with or without drop blocks would be different correct? So with say 2" drop blocks and flipped trailing arm mounts, is that going to be too much. Is it "more the merrier, or find the happy medium?
Ackattack is offline   Reply With Quote
1972 chevy, c-10, no limit engineering
