#26 |
Re: How can i improve a lil bit on gas mileage
Is your truck 2 or 4 wheel drive? My 383 has been getting 10-12 mpg, depending on how it's driven.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
#27 | |
[><]Sofa King Dirty 4x4[><]
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
#28 |
2 wheel
#29 |
'screaming' or not... fuel efficiency is about volumetric efficiency.. where your rpm's land is where they land 'screaming' is usually better than lugging around...
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#30 |
i had a 83 swb with a hot sb 400 most the parst came out of my dads super street race car it had a high gear and 700r4 with a 4bbl holly 600+- and was able to get 15 must have just been that right combo of course when i got into it it would kill a tank in a hurry
81 Stepside http://67-72chevytrucks.com/vboard/s...d.php?t=435795 |
#31 |
Well imma just hook the 4brl up gets 3.73's gears and still check for leaks just incase i appreciate it guys
#32 |
so you have a 2bbl 383, with a th350, 2wd with 33" tires and 3:23 rear gears? first put the 4bbl back on and give it a tune up, plugs, wires k&n filter, timing set prop. then change the tires to something normal say around 28". even 31's would be better than the 33"s. that should help some, then look for a 700r4.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#33 | |
and now with that said you pointed out one thing that needs to be fixed first. you said the filler tube hose has a crack in it your sucking air in to the tank and you have an open system that works best closed with negetive pressure. its just like leaving the gas cap off whats happening is your pump can suck MORE FUEL easier because it dosnt have the back pressure and by not having the back pressure it also creates a syphon
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#34 |
Happy to be here
![]() Join Date: Mar 2000
Just so you know...An oxymoron is a figure of speech that combines contradictory terms. Oxymorons appear in a variety of contexts, including inadvertent errors such as extremely average
#35 | |
#36 |
all you guys with 383's+ are making me feel bad about my 305 with a mild cam getting 9mpg
| Bookmarks |
