Old 03-20-2011, 08:14 AM   #6
sumran
sumran's Avatar
Re: Cruise control
Originally Posted by DREAMER1 View Post
Tell me more about ur setup. Did you install it yourself, if so how difficult was it? What about the switch? And the engine comportment, is it big an bulky or is it tucked away neatly?....give me some more info
The system I have in my Dodge came with it. I will be installing one that I am buying for the my current project. The controller is a turn signal lever replacement. They make them for various styles. The heart of the system is an electronically controlled device that manipulates the throttle just like a driver pushing the the accelerator. It get speed info from the insert and connects to the brake light switch to turn it off when you use the brake.
The electrical install is fairly straight forward. Getting the controller and cable installed well will the most demanding part. But that shouldn't be too bad. Hopefully some others that have already installed the system will join in. Otherwise, I will tell you how it goes in about 6 weeks.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
cruise control
